989 is only charging at 42000mah at .5 amps max
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> MRC Charger Product Support (i.e. Super Brain, etc) >> 989 is only charging at 42000mah at .5 amps max
Page: [1]
Login
989 is only charging at 42000mah at .5 amps max - 3/31/2008 3:40:01 PM
RCJesse
Status: offline
I have two similar 6 cell Intellect 4200 Batteries. One them charges fine, the other one don't charge at the 3+ amp I set it for. It stays at .3-.5 amps, as if it was trickle charging. I tried the cycle mode to see if it would discharge normal, but it doesn't, it also only discharges at .3-.5 amps.
The I test it with a basic peak charger, and it charges fine. I even ran my truck with it for about 30 min. with no issues. What could be the problem? I have other 7 cell and one 8 cell battery and this is the only one that gives me that problem. Could it be the battery memory?
_____________________________
E-Maxx, Rustler & Stampede XL-5's, Stampede VXL, TB02(clone) drift.
       Post #: 1
RE: 989 is only charging at 42000mah at .5 amps max - 4/2/2008 4:28:28 PM
Tim@MRC
Status: offline
I haven't heard of that before. It could be the connection on that particular battery. All other batteries charge and discharge fine on the 989?
(in reply to RCJesse)
       Post #: 2
RE: 989 is only charging at 42000mah at .5 amps max - 4/2/2008 10:32:11 PM
guver
Status: offline
New one to me too, I'd like to try to duplicate it.
2 questions come to mind.
Are you poweering up the charger before hooking battery?
WHAT is the voltage doing during the charge? (on the problem battery)
This is an apostrophe ''
(in reply to Tim@MRC)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
