DX6i Fire Buttons    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> DX6i Fire Buttons
Page: [1]
Login
DX6i Fire Buttons - 3/31/2008 10:32 PM
grompix
Score: 100
Last Login: 7/2/2009
Status: offline
My Spektrum DX6i arrived on Saturday morning. After struggling all day trying to figure out how to use some of the extra switches to operate the main gun and MG I picked up on this thread...
http://www.rcuniverse.com/forum/m_7301841/tm.htm
With the help of those guys I managed to get the Mix configuration so that two switches fired the main gun amd MG repectively.
However, When it came to my Sherman and Pershing tanks the two mix functions were used up with firing and there was nothing left to operate the lights (and the startup on the Pershing). No doubt someone on this forum will now point out that you can do so-and-so to achieve this but I decided on doing it the same way as I have on my old Futaba Skysport Txs. I soldered fire buttons to the elevator potentiometer. Not for the fainthearted I'll admit but here's how I did it in case anyone else is feeling reckless!
I can now fire the guns and save the Flaps, Gear and Mixes for other things.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
"A Sherman can give you a very nice edge."
Hide Signatures
       Post #: 1
RE: DX6i Fire Buttons - 4/1/2008 1:07 AM
erikreid
Score: 100
Last Login: 10/4/2008
Status: offline
nice work. I only have the DX6 so all i did was change one switch to a button and converted that to the main gun, I just kept the setting for the MG to fire with the stick to the rear set up. great work. i like the detail you put in with the pics for us visual peeps.
current projects: Jadgpanther, possible U-Boat (still deciding)
Hide Signatures
(in reply to grompix)
       Post #: 2
RE: DX6i Fire Buttons - 4/1/2008 1:32 AM
hdbeast
Score: 106
Last Login: 5/9/2013
Status: offline
Thanks, This is a lot of help that would be nice to see in FAQ section.
Gary
HL Panzer III & IV, Persing, Bulldog, Jagdpather, T34/85 upgraded with HL, Tamiya Sherman and King Tiger, Mato Sherman.
Hide Signatures
       Post #: 3
RE: DX6i Fire Buttons - 4/1/2008 2:02 AM
Jeff489
Score: 105
Last Login: 5/20/2013
Status: offline
Niiiiccce. Did I say nice?
You just saved me hours. I'm doing this same project this coming weekend on my Dxi.
Thanks!
Hide Signatures
(in reply to hdbeast)
       Post #: 4
RE: DX6i Fire Buttons - 4/1/2008 3:12 AM
Dugster
Score: 100
Last Login: 8/4/2010
Status: offline
grompix, where did you get those cool looking push buttons? Distributor and part number?
Man will occasionally stumble over the truth, but he usually manages to pick himself up, walk over it, and carry on.
Hide Signatures
(in reply to Jeff489)
       Post #: 5
RE: DX6i Fire Buttons - 4/1/2008 4:17 AM
James S.
Score: 100
Last Login: 12/13/2008
Status: offline
to take care of the safety lock set your reverse End Point Adjustment (EPA) to 125% that will allow you to unlock the tank by quick full reverse and letting go of the stick. (if the stick auto centers)
Hope this helps
Hide Signatures
(in reply to Dugster)
       Post #: 6
RE: DX6i Fire Buttons - 4/1/2008 4:30 AM
Planedev
Score: 100
Last Login: 9/3/2009
Status: offline
When I was using my airtronics super 6000 I had my tank connections set up in the following way
Aileron channel = Rudder
Throttle channel = Throttle
Elevation channel = Gun elevator
Rudder channel = Turret turn
That way I can do set up in low dual rates(100% throw) and a master arm switch when I set it to high dual rates(150% throw). This way I can mix the flap channel to Right full rudder to activate the head lights of my pershing. For the pershing engage gear system I just use teh throttle cut function set to -50% and when I need to engage teh gear, I press that button and move my throttle stick to full reverse for a split second after which I put tehthrottle backto neutral and let go of the throttle cut switch and she is ready to go.
Hide Signatures
(in reply to James S.)
       Post #: 7
RE: DX6i Fire Buttons - 4/1/2008 10:56 PM
grompix
Score: 100
Status: offline
Very glad you all find it useful folks. Thanks James S and Planedev - I knew someone would have solutions for the Pershing startup and lights! Never mind, I'm still happy to have added the extra buttons as it gives me more options to use buttons and switches to activate other things.
BTW someone on this forum mentioned recently that the DX6i is quite sensitive to Tamiya DMD 'differences'. I found that out when I set up my Tamiya Tiger 1 by copying my Panther modelmatch settings. Lo and behold - I can get the main gun OR the MG to fire with my new buttons but not both (only one without the other). The Panther works perfectly. Very strange, especially since the Panther and Tiger DMDs are supposed to be the same. I'll have to mess about a bit more with the settings to see if I can resolve the issue.
Chris
Hide Signatures
(in reply to Planedev)
       Post #: 8
RE: DX6i Fire Buttons - 4/1/2008 11:00 PM
grompix
Score: 100
Status: offline
I nearly forgot Dugster. I use Rapid Electronics a fair bit here in the UK. I suppose Radio Shack would be your equivalent in the USA.
Here's a link to the type of button I used.
http://www.rapidonline.com/Electronic-Components/Switches/Push-Button-Switches/Miniature-SPST-momentary-push-switches/71431
Chris
Hide Signatures
       Post #: 9
RE: DX6i Fire Buttons - 4/5/2011 5:38 AM
dlobmwm3
Score: 100
Last Login: 5/23/2013
Status: offline
I tried all your suggestions but I still can't get the main gun to get configured to one of the switches on my dx6i.  Please help as this it the very last thing on my son's Sherman birthday present for May 2nd.
Tam Panther G, Tam KV-2, T-34/76 1943 Daryl Turner Edition (WSN/Tamiya), T-34/76 1942 Daryl Turner Edition (WSN/Tamiya)
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.219RCU1
