SJ 50 Prop????
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> SJ 50 Prop????
Page: [1]
Login
SJ 50 Prop???? - 3/31/2008 8:11:31 PM
MALIBU540
Status: offline
Hello.
I received mi new baby today …..
I have a jett SJ50 whit the stock tuned muffler for this bb, and I have some questions for you…
The new plane it’s a Weston Magnum R ….
what propeller do you recommend for this plane, for speed in a dive …??????????.. .
Is there any chance to convert mi engine to the new 60lx….?????
Thanks for you time.
Best regards.
Teodoro Overhage.
       Post #: 1
RE: SJ 50 Prop???? - 3/31/2008 8:56:27 PM
bob27s
Status: offline
Hi,
Thanks for writing.....
Always happy to answer questions....
First, be certain to follow the run-in instructions - use a 9x6 or 9x7 for initial run-in, or a 10x6 cut down to 8.5" diameter.
Prop selection is all based on the engine's design rpm. For the SJ-50, you select a prop that allows the engine to turn over 16,500 peak ground rpm. It is happy with everything from a 9x6 through a 10x6 or 11x5 even... all hit the target range.
For flight, find peak rpm (briefly) then back down 800 rpm rich from there before launch.
After that, start flying with a standard blade APC 9x7 or 9x8.
That will give you lots of top end speed, will keep the engine in its proper rpm band, and will most importantly give you an execellent launch. Use those first flights to see how the engine responds to the mixture. You may have to lean/richen a tiny bit from where described above.
After you have some time on both the engine and airplane --- and understand how both work together .... try an APC 9x9. You may also want to try an APC 8.8x8.5 --- but beware the launch thrust with either of these will be a bit lower than with the 9x7 or 9x8.
The standard SJ-50 is one heck of an engine.... dont sell it short Prop it correctly and it will make that Magnum really move.
If you want to focus on speed a bit, you can contact Dub and get the LX muffler (higher rpm tuning).
This will force you to prop the engine to turn over 17,500 ground peak -- means lighter prop load, but better in flight rpm.
With this you would use a 9x7, 9x8 (largest), 8.8x8.5, 8.75x8W and also the 8.5x7.25 (yes, this works great...).
As for the engine....
Not economical to convert the engine. Everything except the carb, bearings, drive washer and muffler bolts is different.
You can update the engine to a SJ-50LX ---- higher timed, higher rpm muffler
VERY near the 60LX performance. Requires piston/sleeve/head and the above mentioned LX muffler. About 500 rpm more than just adding the muffler when using any of the props abouve (except the 9x9) and you will definately want to try the 8.8x8.5 prop.
And.. in this particular application ----- APC 8.8x9.25, clip to a finished diameter of 8".
Bob
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to MALIBU540)
       Post #: 2
RE: SJ 50 Prop???? - 4/2/2008 11:50:05 PM
MALIBU540
Status: offline
Hi Bob..
Thanks for the fast reply……
Let me call Dub and get the LX muffler …..
Thanks again for the fast respond…
       Post #: 3
RE: SJ 50 Prop???? - 4/24/2008 7:07:30 PM
MALIBU540
Status: offline
Hi bob..
I’m so happy whit mi SJ50 engine…… and mi magnum r…
Here is some information of mi dives….
Dive 1 prop 9 x 7 speed= 171.17 Mph
Dive 2 prop 9x 8 speed= 176.25
Dive 3 prop 9x9 speed= 177.52
Dive 4 prop 8x9 speed= 186.25
Dive 5 prop 8x10 speed =203.37
The new props to test 8.8x8.5, 8.8 x 8w and 8.5 x 7.25
Best regards.
       Post #: 4
RE: SJ 50 Prop???? - 4/24/2008 7:52:09 PM
bob27s
Status: offline
Excellent..... !
Thanks for the feedback Always good to see a satisfied customer
the 8x10 was a bit of a surprise, bit it appars to work in the application !
You might want to try a 8.8x9.25 - cut it to 8" diameter and just clean up the tips and balance it.
Bob Brassell
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.454RCU1
