RE: ESKY LAMA 4 THREAD    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> RE: ESKY LAMA 4 THREAD
Page: <<   < prev  29 30 [31] 32 33 34 35 36 37 38   next >   >>
Login
RE: ESKY LAMA 4 THREAD - 12/9/2008 5:16 AM
USHobbySupply
Score: 100
Last Login: 2/6/2011
Status: offline
If you run a shorter flybar, the heli will respond much better!
_____________________________
Michael Bernstein, President, USHobbySupply
Please PM me if I miss your question in a thread
Hide Signatures
(in reply to shenlonco)
       Post #: 751
RE: ESKY LAMA 4 THREAD - 12/9/2008 5:21 AM
Wheelnut
Score: 161
Last Login: 5/23/2013
Status: offline
That is an interesting statement since My CX flies pretty fast. I will get a vid when I get a change.
If it''''''''s not broke, fix it until it is
Hide Signatures
       Post #: 752
RE: ESKY LAMA 4 THREAD - 12/9/2008 5:33 AM
USHobbySupply
Score: 100
Status: offline
the flybar is the key link to the stability of these coax machines. the shorter the flybar the less inherently stable they are and the more they will respond to input from the pilot.
Hide Signatures
       Post #: 753
zorecati
Score: 100
Last Login: 4/28/2010
Status: offline
I'm not sure what you are comparing the speed too. It's really meant to be flown indoors and compared to even something like a hbfp, it's pretty pokey. That doesn't mean it's not fun.
Hide Signatures
(in reply to Wheelnut)
       Post #: 754
RE: ESKY LAMA 4 THREAD - 12/9/2008 5:51 AM
shenlonco
Score: 124
Last Login: 10/29/2012
Status: offline
Hi i don't think a shorter flybar will make it move farward faster... don't you need longer servo horns so it moves everything a little more to make it fly in all directions faster?
Shenlonco
Hide Signatures
(in reply to zorecati)
       Post #: 755
RE: ESKY LAMA 4 THREAD - 12/9/2008 5:53 AM
shenlonco
Score: 124
Status: offline
quote:
ORIGINAL: Wheelnut
Could it have been the 25 degree weather that caused it to feel slower?
maybe there was some funky swirly wind but i did not see any movement at all from the trees or the long grass i have by my pond?
Shenlonco
Hide Signatures
       Post #: 756
RE: ESKY LAMA 4 THREAD - 12/9/2008 5:59 AM
Wheelnut
Score: 161
Status: offline
I forgot to mention that it is alot easier to mod the CX because the Servos face parallel with the heli and have a longer stock servo horn than the Lama does so you can move the linkage to the outer most hole for much faster movement.
The lama is the opposite. You have to buy a longer servo horn since the stock one was cut off so it doesn't hit the body, when you install the longer servo horn on the Lama you have to trim the body so it doesn't hit. Then it will fly faster.
Hide Signatures
       Post #: 757
RE: ESKY LAMA 4 THREAD - 12/9/2008 6:29 AM
shenlonco
Score: 124
Status: offline
cool i am trying to find the parts i seen one guy on e-bay selling them but he wants $6.00 to ship them!!!
do only e-flight cx and cx2 servo horns fit?
Shenlonco
Hide Signatures
       Post #: 758
RE: ESKY LAMA 4 THREAD - 12/9/2008 6:34 AM
zorecati
Score: 100
Status: offline
No, you'll need them for an esky servo although others may fit. Eflight wont.
Hide Signatures
       Post #: 759
RE: ESKY LAMA 4 THREAD - 12/9/2008 7:11 AM
shenlonco
Score: 124
Status: offline
quote:
ORIGINAL: zorecati
On another V4 board they are all saying E-flight ones will work
these ones
http://www.wholesaletrains.com/Detail.asp?ID=200469359
Shenlonco
Hide Signatures
       Post #: 760
RE: ESKY LAMA 4 THREAD - 12/9/2008 1:05 PM
zorecati
Score: 100
Status: offline
I have both. I assure you, they will not. The splines are different. Mind you these are not the digital servos. The horn you posted is for eflite. I think it's even an eflite part number.
Hide Signatures
       Post #: 761
RE: ESKY LAMA 4 THREAD - 12/9/2008 5:30 PM
shenlonco
Score: 124
Status: offline
the V4 has digital servos so will they fit?
Shenlonco
Hide Signatures
       Post #: 762
RE: ESKY LAMA 4 THREAD - 12/10/2008 2:51 AM
hottrk51
Score: 100
Last Login: 1/26/2012
Status: offline
OK. The TBE is mostly GONE! I pulled off all the aluminum parts and put the stock plastic stuff back on. Then I adjusted, adjusted, adjusted and adjusted some more. Not quite perfect but at least I can control it. Still need some right rudder to keep from spining very slowly but that will come.
IMHO loose the aluminum! Got 2 sets for sale if you still want them!
Thanks to all for the help. I'll keep you posted.
Hide Signatures
(in reply to USHobbySupply)
       Post #: 763
RE: ESKY LAMA 4 THREAD - 12/10/2008 3:05 AM
zorecati
Score: 100
Status: offline
quote:
ORIGINAL: shenlonco
That is a good question and one I do not have an answer too. I read that the horns from the non digital eflight were different from the digital. Just my 2 cents, but moving the rod out wont make that much of a difference at least from my testing. I have flown the thing a bunch out side and after having it snatched from me due to wind, I finally got a honey bee fixed pitch. I highly recomend it if your intent is to do more outside flying.
Hide Signatures
       Post #: 764
RE: ESKY LAMA 4 THREAD - 12/10/2008 3:41 AM
Wheelnut
Score: 161
Status: offline
Is the Honey Bee fixed pitch any more stable than the Falcon 40? Somehow I doubt it. I couldn't fly the Falcon 40 to save my life. I could hover it for about 30 to 45 seconds and that was it. I prefer to fly my CX outside.
Hide Signatures
       Post #: 765
RE: ESKY LAMA 4 THREAD - 12/10/2008 3:53 AM
zorecati
Score: 100
Status: offline
quote:
ORIGINAL: Wheelnut
Remember, you don't really fly a coax, they kind of fly themselves. You just sort of point them. I guess it would be the same as the falcon 40 but I found the fp with a pair skids to be more robust, and possibly cheaper to fix. The giggle factor is much higher when you finally do get the hang of it.
I tried going from the lama to a blade cp and then a belt cp and then a king. It wasn't until the fp that I finally figured it out. I'm not trying to sell anyone on anything but you I personally never enjoyed flying the lama outside. It's kind of breaks into bits when you crash it.
fp fun
Hide Signatures
       Post #: 766
RE: ESKY LAMA 4 THREAD - 12/10/2008 4:21 AM
shenlonco
Score: 124
Status: offline
Hi Guy's i was looking at this one it supposed to fly nice...there is a video on the site.
Shenlonco
Hide Signatures
       Post #: 767
RE: ESKY LAMA 4 THREAD - 12/10/2008 4:39 AM
theTman
Score: 100
Last Login: 10/15/2009
Status: offline
if i practice with a simulator a lot before hand, is the honeybee king FP safe indoors? I have read about how coaxials get boring because they are so simple to fly? I can fly it outside of course, but when you have temps in the single digits, or below zero it is preferable to stay inside. maybe a smaller FP would be a good idea.
Hide Signatures
       Post #: 768
RE: ESKY LAMA 4 THREAD - 12/10/2008 5:03 AM
shenlonco
Score: 124
Status: offline
quote:
ORIGINAL: theTman
Did you ever fly a heli before?
If not get a MCX by e-flight it will teach you alot and it's the most easy heli on the planet to fly.
Shenlonco
Hide Signatures
(in reply to theTman)
       Post #: 769
RE: ESKY LAMA 4 THREAD - 12/10/2008 5:11 AM
Wheelnut
Score: 161
Status: offline
[/quote]
[/quote]
That is what I like about it, because I can't fly a real style heli.
Shenlonco,
That is what they all say. (Flies nice) yeh, until I fly it
I'll stick with the coaxials for quick simple fun, because I spend alot more time flying planes and enjoy them much more.
Hide Signatures
       Post #: 770
RE: ESKY LAMA 4 THREAD - 12/10/2008 5:19 AM
shenlonco
Score: 124
Status: offline
I have planes also vapor and cessna from parkzone fun fun FUN!
quote:
ORIGINAL: Wheelnut
Shenlonco,
Shenlonco
Hide Signatures
       Post #: 771
RE: ESKY LAMA 4 THREAD - 12/10/2008 5:41 AM
theTman
Score: 100
Status: offline
on second thought, i think i will go with a coaxial for starters. the only heli like thing i have ever flown, i wouldn't even call it a true heli, was one of those 2ch things that only goes up and down, and will only go forward it the nose is weighted, and then it is going forward constantly. i guess i should go for a coaxial first to learn basic controls. also, i will hopefully have a job by the time it is nice enough to fly outside regularly, and by then i will have enough experience to move up to something better. i guess i will go with a co-comanche for starters and then step it up to a FP, and then a CP.
Hide Signatures
       Post #: 772
RE: ESKY LAMA 4 THREAD - 12/10/2008 6:51 AM
Wheelnut
Score: 161
Status: offline
Just to share with you guys,
My first heli, about 4 or 5 years ago was the Roto fly. What a nightmare that thing was. But at the time, I thought it was the coolest thing. Then I got the House Fly, a much better heli, that I could actually fly. Or should I say, it flew itself , but I did feel like I was doing something
Hide Signatures
       Post #: 773
1500valk
Score: 100
Last Login: 5/22/2012
Status: offline
ok, i seem to have a problem with my swashplate on my dauphin. This picture shows what happened when I was just checking some parts for excess play.
the parts snap back together, but are they supposed to be "two" pieces? If this isn't normal, will just upgrade to the xtreme swash. Any problems with the xtreme swash I need to know about? Direct fit? i don't really have the budget for the rest of the xtreme rotor head parts. (I already have the xtreme taller inner shaft and their white blades).
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 774
RE: ESKY LAMA 4 THREAD - 12/10/2008 6:55 AM
Wheelnut
Score: 161
Status: offline
Looks like you have some nice motors on there
Sorry, not sure about your question. Hopefully someone else will know.
Hide Signatures
(in reply to 1500valk)
       Post #: 775
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.555RCU1
