RE: ESKY LAMA 4 THREAD
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> RE: ESKY LAMA 4 THREAD
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: ESKY LAMA 4 THREAD - 6/24/2008 12:27:49 AM
joeyhatch11
Status: offline
Hey Gerald, Please let me know how those 1000mah batteries are. I was looking at them myself but didnt know if they would be any good. I dont believe they'll give you more power just longer run times. Maybe just a few minutes though. It's only 200mah over stock.
I'd like to see a 7.4v 1500mah battery that will fit my lama 3
(in reply to gerald77)
       Post #: 251
RE: ESKY LAMA 4 THREAD - 6/24/2008 4:16:30 AM
superstocktx
Status: offline
I bought a 1000mah battery from china for my V4 $15.00 total shipped to the house, works great. Yeah maybe a minute or two more run time, but hey...more flight time!!!!
_____________________________
R/C CARS, TRUCKS, BUGGYS, STADIUM TRUCKS, PLANES AND HELI''S AND NOT ENOUGH TIME TO FLY AND DRIVE!!!!!
(in reply to joeyhatch11)
       Post #: 252
RE: ESKY LAMA 4 THREAD - 6/24/2008 11:45:30 AM
joeyhatch11
Status: offline
hahaha true. I ordered two of the stock Esky batteries for my Lama 3 from Hong Kong. My packs are getting 11-13 minutes. But I'm still thinking I need another pack or two. Well my Xtreme tail boom and Xtreme shaft should be here today. Can't wait to get that stuff on and take her outside to see how much better she flies.
(in reply to superstocktx)
       Post #: 253
RE: ESKY LAMA 4 THREAD - 6/24/2008 1:52:45 PM
downunderdog
Status: offline
quote:
Its flying a lot better since although not yet as smooth as when i had no upgrades installed. Will keep on tweaking and investigating and let you know if i find any other issues that might be affecting stable flight.
Do a google search of "lama tbe cure" and a lot of stuff comes up. Some things people recommend:
- boiling the blades (I've never done this)
- balancing the blades (pull the pair of blades off with the grips, fasten them back togehter off of the heli, and balance the two cyclic input knobs on film cannisters or similar and ensure that they sit level)
- ensure the flybar is straight and balanced
- ensure the inner and outer shafts are both straight
- lubricate all of the moving surfaces (I did use vaseline where the CNC blade grips pivot on the rotor head when I was having TBE, and it didn't seem to help)
- hang the heli from a fishing line and ensure it's balanced fore-aft and left-right
- ensure swash is completely level
There are a lot of things, or combinations of things, that cause it. You just have to keep eliminating them one by one...
       Post #: 254
RE: ESKY LAMA 4 THREAD - 6/24/2008 2:36:49 PM
superstocktx
Status: offline
I have 3 battery packs for the V4, the Esky ones are to expensive. then i have to have 2 for the king 2 and two for each of the 3 planes i have, lipo's arent cheap!!!! i see ur in nj. i lived in lakehust for awhile
       Post #: 255
RE: ESKY LAMA 4 THREAD - 6/24/2008 8:15:00 PM
gerald77
Status: offline
1500mAh would be very interesting!! Will let you know how it went with a 1000. For now i am trying to sort out quite a bit of vibration on the v4.Think i have found the prob,it lies with the centre area,either the `A` shaft or bottom one,seems to be slightly bent from the `quick landings`. Tried to remove the lower shaft collar set but the small screw holding it in place is a toughie. Any idea what i can do apart from applying strength?? Looks like the factory applied threadlock is almost permanent.Help!!
       Post #: 256
RE: ESKY LAMA 4 THREAD - 6/24/2008 8:35:01 PM
USHobbySupply
Status: offline
When things are locktighted in with red, it requires a bit of heat to 'unlock it'. I use the tip of a soldering iron, and let the heat transfer to the part for a good minute or so. That usually loosens them up!
Michael
Michael Bernstein, President, USHobbySupply
Please PM me if I miss you question in a thread
       Post #: 257
RE: ESKY LAMA 4 THREAD - 6/24/2008 8:51:25 PM
gerald77
Status: offline
Thought about heat but wasnt sure. Thanks for confirming i wont be losing my time trying that. Is there any specific reason why they use the red stuff,will my normal TL hold the screw in place once i have put it back?? I still got a lot of tricks to learn by the looks of it. Thanks for your help
< Message edited by gerald77 -- 6/24/2008 9:56:05 PM >
(in reply to USHobbySupply)
       Post #: 258
RE: ESKY LAMA 4 THREAD - 6/24/2008 10:15:14 PM
gerald77
Status: offline
Interesting to see what some people do.Boiling!? hehehe. Seriously though,i think that my tbe is caused due to the slight bend on the bottom and top shaft. Noticed this today and hopefully will confirm that this is the problem by replacing the parts. Will keep the other recommendations in mind just in case i am wrong. Do some people really boil the blades??? bet they taste better eh?? haha. Anyway,thanks for the advice and for the record......would boil them myself if i knew that would improve my skills!! The force is not yet with me i`m afraid. Cheers
(in reply to downunderdog)
       Post #: 259
RE: ESKY LAMA 4 THREAD - 6/24/2008 11:54:34 PM
joeyhatch11
Status: offline
Has anyone here ordered from KR's Hobbies? I bought something on Thursday and paid for Parcel Post and still don't have my new tail boom. Or a tracking number to follow it. I thought through Parcel Post your supposed to get a tracking number? Damn do they suck.
       Post #: 260
RE: ESKY LAMA 4 THREAD - 6/25/2008 1:17:41 AM
GTX SlotCar
Status: offline
quote:
......would boil them myself if i knew that would improve....
Boiling the blades is OK, but it takes out most of the flavor. I prefer mine deep fried in batter.
quote:
Has anyone here ordered from KR's Hobbies? .....I thought through Parcel Post your supposed to get a tracking number?
I don't believe normal parcel post includes tracking and it takes about 7 days for delivery. Priority Mail does have tracking, but you have to ask the postal clerk to scan the package. As far as I know, KR's has been OK.
Gary
SuperSkids® www.super-skids.com
       Post #: 261
RE: ESKY LAMA 4 THREAD - 6/25/2008 1:30:16 AM
Bones27
Status: offline
Boiled blades aren't bad if you boil them in crab boil!
Don''''t let schooling interfere with your education.
Mark Twain
(in reply to GTX SlotCar)
       Post #: 262
RE: ESKY LAMA 4 THREAD - 6/25/2008 1:56:35 AM
USHobbySupply
Status: offline
Rare for me please!!
(in reply to Bones27)
       Post #: 263
RE: ESKY LAMA 4 THREAD - 6/25/2008 2:06:43 AM
joeyhatch11
Status: offline
For a package costing me $10.00 to ship, they sure as hell should offer a tracking number. I'm just pissed cause I ordered other things too that day and I've got them already, some today and one even yesterday. And they were the same distance away if not a little further. All I'm asking is what gives? hahahaha Sorry had to get that one out. Much better now. Thanks hahaha
       Post #: 264
RE: ESKY LAMA 4 THREAD - 6/25/2008 2:16:35 AM
USHobbySupply
Status: offline
FYI, goldslinger custom flybars for the CX2 and Lama are ready!!!! Nearly unbreakable! (maybe if a mac truck runs over your heli, then they will break)
       Post #: 265
RE: ESKY LAMA 4 THREAD - 6/25/2008 10:05:33 PM
