joeyhatch11
NJ, USA Status: offline
The same weights I use on my stock/modified fly-bar, I use on the Xtreme Short fly-bar. But I get nasty TBE. I added two wheel locks, one for each side, and it seemed to calm it down a bit but was still there. So I went back to the stock one and it went away. But let me tell you this. I was out back flying and noticed that it was reacting alittle funny, so I brought it in. Turns out the screws on the bottom half of the outter shaft came loose and the swash plate and everything moved up. I turned everything on and pushed it back down till the swash plate was leveled. I think it's where it should be but could still be a little off. That may be why I had some of that TBE. I'll play around with it later and let you guys know what I find and how I made out. But thanks for the reply. It helped.
