downunderdog
Joined: 7/7/2007 From: Sydney, AUSTRALIA Status: offline
I just bought the metal upgrade kit for my V3 from: http://www.rchelicoptershop.com I agree that the metal blade holders are junk. Too many little pieces, and all held together by tiny screws. After figuring that out the hard way (had one of the little balls on the side that attach to the swashplate and flybar linkages, which I figured should have been glued in there, come loose on the first flight... it took about 20 minutes searching the floor to find it), I tightened everything up and flew for about a battery worth, with major TBE the entire time. Towards the end, I was holding the skids and looking at the blades to see if I could figure out what was causing the TBE, and one of the blade assemblies (whole blade, plus the half of the metal blade grip/holder) came off and went shooting across the room - luckily away from me instead of at me. Two of the screws that I had tightened before that flight had come loose and let go. That, combined with the horrendous TBE, made me switch back to the plastic blade grips/holders. I still have a bit of TBE with the plastic grips, and am suspecting the upgrade swashplate as the culprit (it didn't feel all that smooth on the shaft as I was installing it). I hope it's not the upgrade turbo shaft that is causing the mild TBE, as the heli seems to be a lot more controllable with the longer shaft, and I haven't had a flybar come off yet (I used to have it come off, or have a blade strike, a couple of times every battery) since I installed it. I'm anxious for a calm day so I can try it outside. When in fast forward flight (which is tricky in our apartment), the TBE seems to go away and I can maneuver pretty well. It should be fun outside. I also bought the rather pricey ($18 for 3 sets) "harden" blades. I've made contact with a few things that would have been the death of the stock blades, and I haven't seen a scratch on them yet... knock on wood. In summary, I'd recommend getting the "turbo shaft" and the "harden" blades, but none of the other upgrade parts in the set. I'll update if I do determine that the turbo shaft is related to the TBE. If anyone finds a cure for mild TBE, then I'd love to hear it.
