superstocktx
MO, USA Status: offline
quote:
ORIGINAL: BigTruckDriver just got my lama and the trims are maxxed out, is this normal? it seems i need more adjustment. what lama did you get? v3 v4? the v3 is much harder to control than the v4 some adjustments of the trims are normal(after lift off), with all trims centered except for the throttle trim(throttle trim all the way down) the heli should stay pretty much in a 1-3 foot area with out much input. if you lift off and it goes flying to the left/right/fwd/back you will need to adjust the control links that go from the servos to the swash plate. if adjustment is needed, carfully pop control link off swash plate and adjust arm as nessisary. you have two control links, one controls right/left the other is fwd/aft. my v4 is at the hobby shop(my second home), so...i forgot witch side controls what movement. and as far as the yaw trim(tail trim) its kinda hit and miss because it will change as the battery wears down. with a full battery and yaw trim centered, the tail drifts to either side you will need to adjust the porpotional(on the 4 in 1 mixer) this will be the adjustment closest to the tail. the front adjustment(the gain) controls how tight the tail is held in place and how fast it reacts to your inputs. if the gail is set to high the tail will twitch side to side rapidly but will have a faster reaction to inputs. less gain will make the tail looser and not react as fast to inputs. to check and see what link needs to be adjusted, turn tx on then power up heli, move right stick for/aft and see wich servo moves. it will fly without front canopy on, this makes it easy to make adjustments to the links. all in all they are great helis, but each one is different out of the box, i work part time at a hobby shop and fly them alot of them. i have all the aluminum upgrades on mine except for the blade grips(dont waste ur money on the alum.grips). the aluminum swash plate takes out most of the slop and makes it more aggressive. i just got done upgrading my esky king 2 with full aluminum, carbon fiber and went brushless, cant wait to fly it . hope this helps, feel free to ask for more help if you need it, Dennis
_____________________________
R/C CARS, TRUCKS, BUGGYS, STADIUM TRUCKS, PLANES AND HELI''S AND NOT ENOUGH TIME TO FLY AND DRIVE!!!!!
