FAAST Receivers and Hitec Servos
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> FAAST Receivers and Hitec Servos Page: [1]
Login
FAAST Receivers and Hitec Servos - 3/31/2008 8:28:15 PM
ExFokkerFlyer
Status: offline
A thread was on the Futaba support forum about issues many are having with Hitec servo compatibility with the FAAST system. All of those posts were deleted today. Fine, their forum, their rules, but it's an important subject so I thought I would post it again here.
To start it off, below is one of my deleted posts:
quote:
If you search other forums you'll see some reports about this problem. I hooked up my 6014, plugged in a 5955 to the 1 Rx slot, then 2, then 3, then 4, then 5... you get the picture. All worked fine. Then, I plugged in two 5955 servos ganged together with a Y connector... first into slot one... and then two. Worked fine. After that I tried 3... 4... 5... etc... everything went crazy each time. The rudder (servos in question were on the rudder) fluttered wildly back and forth quickly. But on one and two it was fine.
Day after that I received the two 608FS Rxs that I ordered... all channels worked fine with one and two servos...
Apparently the signal voltage on the 6014FS is lower than norm on channels 3-14. 1 and 2 are 3.3V, the rest are 2.7 I believe (not an expert, just read it somewhere, search the jet forum for more info). The fix for this is to use a Powerbox, Smart-Fly or what-have-you. I bought this system to avoid having to do that... and now it appears that in order to use this system I MUST use these other products. Sure I could just use Futaba products, but what do I do with the thousands of dollars of Hitec servos that I have??? Guess I shouldn't have bought them.
Anyway, the 608FS appears to work, but I don't really trust it and will likely use two of those along with a PowerBox to solve some of my problems... that way I know that voltage will remain at acceptable levels, the 6014FS is certainly not reliable how I want to use it, unless I put a Powerbox or Smart-fly board in the picture.
Though this shouldn't be posted in Futaba's forum, it will likely be deleted.
Here is a thread here on RCU that provides more info.
http://www.rcuniverse.com/forum/m_7243983/tm.htm
_____________________________
Any pilot can describe the mechanics of flying. What it can do for the spirit of man is beyond description.- Barry Goldwater
       Post #: 1
RE: FAAST Receivers and Hitec Servos - 3/31/2008 8:45:43 PM
Crismedicatrix
Status: offline
5x 645MG with fut 606 FASST no problems !!!
Happy Flying!
(in reply to ExFokkerFlyer)
       Post #: 2
RE: FAAST Receivers and Hitec Servos - 4/1/2008 3:21:32 AM
ExFokkerFlyer
Status: offline
Only an issue with the 6014fs and te 5955TG so far as I know... a lot of IMAC/Giant scale 3d guys use this combo, or better said, might use it when they convert over to 2.4... I tried it and it ABSOLUTELY does not work without the use of a powerbox, smartfly expander, or $1000 in new FUTABA servos... Futaba has said that they will not be held responsible for the compatibility of other manufacturers products... okay, fine, put that on the box or the online ad, and we won't have a problem. Say that in a thread after I plunked down $4k for radios and another K or so on Rxs... then I REALLY have a problem... and I do.
(in reply to Crismedicatrix)
       Post #: 3
RE: FAAST Receivers and Hitec Servos - 6/20/2008 2:20:53 PM
SoCalSal
Status: offline
There has been a few problems with 5955's and the R6014FS recevier. The Recevier's signal output voltage is 2.7. volts. This is below the current Hitec voltage of 3.3 volts.
The strange problem happens with some but not all HiTec ( maybe others as well) servos. I have about 15 5955's in a couple different planes. I also have the R6014FS recevier in one plane that has the 5955's hooked stright into the recevier and so far no problems. This maybe due ( My own ideas) the fact that I am only running 6 servos in this plane. So I think the signal voltage is not dropping below 2.7 due to the mild load on the servos.
Now I do Have a plane with a PowerBox 40/16 Evolution in it. I sent this PowerBox back to Germany to have it updated top work with the F6014FS recevier. This set-up gives me a better feeling of safety when flying my 30% planes and is the recommended way of useing the R6014FS recevier with non Futaba servos. However. you must make sure the PowerBox is set up for the new standard. If it has a yellow dot on the back then you are O.K. if not then check with the manaufacture before useing to see if it will work.
PowerBox will update any PowerBox at no cost (other than shipping to them)and send it back to you and they pay the return postage........ time frame is about 3 weeks........ it takes about 10 days to snail mail the unit to them.
Just remember. if the servos seem to work "on the bench" they may fail in the air where there is more of a load on them..maybe not???????? To be safe, use only Futuba servos or get a power managment system of some sort. PowerBox, SmartFly or any of the other ones out there..
Hope this helps some people.
Let''s be open minded.... But not so open that your brain falls out
       Post #: 4
RE: FAAST Receivers and Hitec Servos - 6/29/2008 11:21:54 PM
Big_Bird
Status: offline
A 10C FASST radio was bought Saturday for use in a 42% plane. I have read a lot about the 2.7 volt signal output problem. All 10 servos that were bought were a combination of Futaba digital servos. In addition I am using a Smart Fly Power Expander because of the potential high current drain. A relatively inexpensive solution to insure a solid link to the servos of a different brand than Futaba might be to use this power expander. Each output from the power expander to a servo is electronically buffered.
I can't explain why Futaba did this with the 6014 receiver. I understand the 608 receiver has are full 3.3 volt signal output.
Click to see fullsize image.
Click for fullsize
Ken
WACO Brotherhood #70
(in reply to SoCalSal)
       Post #: 5
RE: FAAST Receivers and Hitec Servos - 6/30/2008 8:19:17 PM
3dd
Status: offline
futaba is going to keep playing these games and find themselfs in the same cemetery as kraft
RON HIGGINBOTHAM
(in reply to Big_Bird)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.549RCU1
