RE: Electra ARF first flights
Tower Hobbies
Logged in as Guest
  Printable Version
Fei Bao Velox Sport Jet - ARF
Seller:  rcjetmodels
Details:   $870.00   |  7/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Electra ARF first flights
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Electra ARF first flights - 4/16/2008 5:18:24 PM
smokin-gun
Status: offline
IT IS HIS TO DO AS HE WANTS, HELL HE CAN STOMP IT ,IF HE WANTS TO.
BUT, YES A BANDIT ARF SEEMS TO BE ALL THEY WILL END UP WITH AND THE BANDIT WILL FLY BETTER , WITH LESS WING LOADING.
YOU CAN TELL HE LOVES TO TINKER AND THAT IS WHAT MAKES FOR NEW INOVATIONS AND OBVIOUSLY HE DOES A GREAT JOB.
GIVE CREDIT WHERE CREDIT IS DUE.
SORRY FOR THE CAPS , JUST NOTICED.
(in reply to jetguy34695)
       Post #: 51
RE: Electra ARF first flights - 4/16/2008 5:22:54 PM
jetguy34695
Status: offline
I agree.
(in reply to smokin-gun)
       Post #: 52
RE: Electra ARF first flights - 4/16/2008 5:43:51 PM
R_Belluomini
Status: offline
Batteries are heavy the 10S 6400 packs weighs 72 oz that''s 4.5 lbs of weight.
I think a well done 54 class turbine conversion will weigh less especially at the critical time............. landing
_____________________________
Wren Turbines USA
       Post #: 53
RE: Electra ARF first flights - 4/16/2008 6:27:33 PM
tamjets
Status: offline
quote:
ORIGINAL: R_Belluomini
Batteries are heavy the 10S 6400 packs weighs 72 oz that''''s 4.5 lbs of weight.
I agree...
This plane done with P-60 is still lighter than E-power.
But for me had both going. If I like doing turbine. I just put in the turbine. If I don''t like get my hand smell like kero. Drop in the electric power plant.
The nice things about this is the size.
I hate the way it mount the wing. Take too long gettting assemble at the field. I saw friend spend extra 45min to assemble and take apart the wing with his bandit.
I refer had it one piece throw in the back of my truck. You can''t do with the bandit.
Tam Nguyen
Owner TamJets
(in reply to R_Belluomini)
       Post #: 54
RE: Electra ARF first flights - 4/16/2008 8:15:44 PM
digitech
Status: offline
quote:
ORIGINAL: jetguy34695
I don''t understand why someone would take a kit that is made for electric power (extra light) giving up strength to make it as light as possible to perform well with less thrust and put a turbine in it when a air frame that looks very similar is made just for that purpose, was it designed to take the additional stress that come along with the added weight of a turbine and fuel system.
Simple i like light models , but not to big
the electra (mini bandit) is perfect
it will do just fine , it was constructed like the bandit
i use bandit servo,s and changed the lg (not more weight)
i am sure it will perform fine
and finnaly i own a van and i do not need to take the electra apart when i want to fly...
Sandor Kruise
Dealers for:JetCat,Graupner,Futaba,Fei-Bao,Pro-Lynx,Airpower,Jets-munt,Xicoy.
"Home of the Jet-1A Gears"
       Post #: 55
RE: Electra ARF first flights - 4/16/2008 8:18:03 PM
digitech
Status: offline
quote:
ORIGINAL: banditarf robert
I see u got the fin on can I see the method it is held on with
well it is hold by a 4mm bearer that comes out of the fuselage.
the bearer is on the inside all the way round
the bearer is then somehow strenghtened with a thin epoxy layer.
and finally fin is glued on the fuselage.
Sandor Kruise
(in reply to banditarf robert)
       Post #: 56
RE: Electra ARF first flights - 4/16/2008 8:21:00 PM
digitech
Status: offline
quote:
ORIGINAL: tamjets
Batteries are heavy the 10S 6400 packs weighs 72 oz that''''''''s 4.5 lbs of weight.
I agree...
But for me had both going. If I like doing turbine. I just put in the turbine. If I don''''t like get my hand smell like kero. Drop in the electric power plant.
I refer had it one piece throw in the back of my truck. You can''''t do with the bandit.
yes exactly and hair dryers are for women and ladyboys
Sandor Kruise
(in reply to tamjets)
       Post #: 57
RE: Electra ARF first flights - 4/16/2008 8:44:28 PM
digitech
Status: offline
quote:
ORIGINAL: tamjets
I agree...
tam with this open construction the wing is simple to take out
i also did NOT cut the bottom hatch , i can undo them from above.
this means also the costruction is better and rigid.
and i dint like it on the old bandit arf eather , toulk me 30 minutes to put on thw wigns and close the hatch
and i agree it is very light , i left a lot of stuff out , and changed them for other things.
i have now 2 x 8411 on the elevators (overkill but safe)
i used a hitec compatible 81 on the rudder
2 x jr8311 on the flaps
and 2 x jr3401 on the ailerons.
i use a emcotec BIC of the powersystem.
and will use the lightest thrustpipe there is that will be a Wren pipe made for the SS.
i will use 2 x 1800 mah for the rx (gives me more then 2 hours flighttime)
and a 20C 2200 for the turbine (gives me about 6 starts)
Sandor Kruise
       Post #: 58
RE: Electra ARF first flights - 4/16/2008 9:26:12 PM
The boys Back
Status: offline
Sandor,
is this going to have a bypass? looks dificult to achieve but it will not be very fast without one,
Dave
(in reply to digitech)
       Post #: 59
RE: Electra ARF first flights - 4/16/2008 10:02:59 PM
k_sonn
Status: offline
quote:
ORIGINAL: tamjets
Batteries are heavy the 10S 6400 packs weighs 72 oz that's 4.5 lbs of weight.
I agree...
But for me had both going. If I like doing turbine. I just put in the turbine. If I don't like get my hand smell like kero. Drop in the electric power plant.
I refer had it one piece throw in the back of my truck. You can't do with the bandit.
It will be interesting to see what the turbine conversion weighs. My Electra weighed 14 pounds ready to fly with batteries. As I mentioned before in other threads, I did not use the heavy EVF system. I used an Aeronaut TF4000 fan made of carbon fiber that weighs 4 ozs. The motor and controller weigh 26 ozs and the 12S batteries I used weigh 48 ozs. That's 78 ozs total for the complete power setup, just 6 ozs more than the weight of the BVM recommended batteries. On Sept 23, 2007 my Electra hit 200mph with this setup, months before BVM made a claim of approaching 200 mph with his second generation of the EVF (at this time the BVM demo Electra was hitting a max of 175 mph out of a steep dive). Here's a date stamped video showing the high speed pass of the Electra.
If the conversion weighs in the 14 - 15 pound range, it should be a rocket.
By the way Sandor, it's nice to see proper retracts on such a nice model
Kirk
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 60
RE: Electra ARF first flights - 4/17/2008 2:50:25 AM
Ron101
Status: offline
Kirk you by far built the best electra I've ever seen
evertime I see it I'm in love.. after my Tam A-4
I'm going to build the electra from a kit and do it up warbird style like yours..
I sent you a pm but I don't think you got it...
were you happy with the TF 4000 in yours? it looks like a simple install in the electra.. I really like the ds 94 fan and would love to try a stumax...
what are your thoughts? stick with the TF 4000 on 1527 12s?
by the way I have not built a kit in years but your electra has inspired me over the last few months.. so I'm going to do it
Ron
"It''''s not personal, Sonny. It''''s strictly business."
(in reply to k_sonn)
       Post #: 61
RE: Electra ARF first flights - 4/17/2008 5:35:33 PM
cgroen
Status: offline
I like that one
(in reply to Ron101)
       Post #: 62
RE: Electra ARF first flights - 4/17/2008 5:45:54 PM
tamjets
Status: offline
quote:
ORIGINAL: Ron101
Ron
Ron,
Are you go to get Stumax fan?
I love to see that fan in action bigger plane.
Everyone been saying how quiet it is. But I haven't even see any video with good speed pass with that fan.
The only two video I see was not that fast all.
Tam Nguyen
Owner TamJets
       Post #: 63
