digitech
Joined: 8/23/2004 From: klimmenlimburg, NETHERLANDS Status: offline
quote:
ORIGINAL: kwb quote:
ORIGINAL: Jack28 I am in the process of building a kit version Electra that I just got from a friend (he changed his mind and bought the new ARF version Electra). I am still deciding on which way to go electric or a Turbine powered conversion. I have been watching the Tam Jets 100 mm fan thread on RC groups , might be a good option for this aitrframe.If I go turbine it would be most likely a Artes Super Bee (14lbs thrust), I fly both electris and Turbine, but this is my largest electric kit so far. Waiting to see what develops with this project. I have just started to build a kit version and will power with either my Wren54 or 44 gold. I think the 44 gold is the likely choice at the moment so I can keep the model nice and light due to the low weight of both the engine and fuel load. Planning on a simple install without a bypass and using the lightweight Wren thrust tube. The 44 gold has nearly 11lb thrust with this tube so the model should go well. Kirk if you need drawings or the parts i can cut them for you drawings are for free , as long no one uses them commercialy.. they are in CRD and PLT whatever you prefer. if you need the parts they are all lasercut i am also using Wrens thrustpipe for the job.. keeping it light
_____________________________
Sandor Kruise Dealers for:JetCat,Graupner,Futaba,Fei-Bao,Pro-Lynx,Airpower,Jets-munt,Xicoy. "Home of the Jet-1A Gears"
