Micro 555 Receiver Max Current?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Micro 555 Receiver Max Current?
Page: [1]
Login
Micro 555 Receiver Max Current? - 4/1/2008 3:39:41 AM
fledermaus
Status: offline
I have an older HITEC 555 4-channel receiver that I am thinking of using. The question I have is how much current can each channel handle? This project will be using one high-torque HS645 servo that draws 350 mA while in motion with no load, while the standard servo draws about 150-170 mA in the same condition.
Can the Micro 555 handle this much current? I also have an older Supreme 8 that I could use although it doesn't fit quite as nicely into the nose compartment of the plane.
       Post #: 1
RE: Micro 555 Receiver Max Current? - 4/1/2008 9:33:01 PM
MikeMayberry
Status: offline
It can handle any high torque servo in all channels with no problems.
Mike.
_____________________________
Hitec RCD Rep
http://www.hitecrcd.com
(in reply to fledermaus)
       Post #: 2
RE: Micro 555 Receiver Max Current? - 4/1/2008 10:16:51 PM
fledermaus
Status: offline
Thanks! I have to run all four ailerons in a sport-scale biplane from a single servo by pull-pull because the wing airfoil is very thin and the nose compartment is too small to put in two standard servos plus the other stuff that needs to go in there.
The Micro 555 will fit very nicely next to the battery and switch right up in the nose!
(in reply to MikeMayberry)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
