blackrider_gr
Joined: 10/23/2006 From: Athens, GREECE Status: offline
Hello Jeff, thank you for your reply, i have 2-3 questions about hawk, Since i have 9xii JR do you suggest me to use Spektrum 2.4 module and 9000 receiver (i m aware that royal can handle very well 2.4 systems) I m thinking of upgrading the Aluminum Tube with carbon tube (is it good or not recommended?) Any inside info about the known issue with the main Tank hole that is positioned at the top 1/3 of it? thank you again for the support!
_____________________________
Football, Basketball, Tennis, Golf Require one ball. Flying Jets requires TWO!!
