67" Fusion ARF/ recovered and maiden ready
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> 67" Fusion ARF/ recovered and maiden ready
Page: [1]
Login
67" Fusion ARF/ recovered and maiden ready - 4/1/2008 7:31:09 PM
daveopam
Status: offline
I am finally ready for the maiden. The wind is up today so maybe Sunday. I am still waiting on the hub but can fly it with the prop nut. I am getting really pumped. If this thing flys as well as the 52" I will be happy. If it flys better than the 52" I will dance a little jig at the field.
I also noticed I must like the covering jobs with all right angles. There is not one curve on the 67" or the 52". Oh well they should both be easy to see.
Set up is Saito 1.25 ,16x6 scimitar series prop. 3305 on rudder,3010s on aile,3152s on elev. 6V Nimih pack and 8ch Futaba RX. I used the supplied pushrods but cut the "Z" of and soldered a clevis. The servo end has Du-bro arms and ball links.
The covering is solid yellow UC. Dark red, insignia blue,met green and trans yellow MC. The gear is composite from OMP painted to match. I will do a flight report after I wring it out a bit.
David
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
"Choose your shirt and shoes by the color. Choose your friends by their character." unknown
       Post #: 1
RE: 67" Fusion ARF/ recovered and maiden ready - 4/1/2008 9:53:42 PM
John Wells
Status: offline
Looks great David!
(in reply to daveopam)
       Post #: 2
RE: 67" Fusion ARF/ recovered and maiden ready - 4/1/2008 10:54:04 PM
daveopam
Status: offline
Thanks John. My thumbs are twitching. After 20 years I still love this hobby!!!!!!!!!!!!!!
David
(in reply to John Wells)
       Post #: 3
RE: 67" Fusion ARF/ recovered and maiden ready - 4/2/2008 12:56:25 AM
Constrictor
Status: offline
I have a kit built 90 fusion ready to test fly too.
OMP Distributor
       Post #: 4
RE: 67" Fusion ARF/ recovered and maiden ready - 4/2/2008 2:14:08 AM
Jeffro
Status: offline
quote:
ORIGINAL: daveopam
David
I have the 52" Fusion and the 67" Fusion. The 52" flies really good.....A really nice .40 size profile. The 67" is unbelievable! Hands down the best 3D plane I've ever flown plus flies nice smooth pattern lines. Mine is flown with a YS 110 and APC 16x4W. Your Saito 125 should be great as well. Now just remember as you're grinning from ear to ear after the first flight.........THE 80" FUSION KITS ARE SHIPPING! HA!
Good luck on the maiden!
       Post #: 5
RE: 67" Fusion ARF/ recovered and maiden ready - 4/2/2008 2:43:59 AM
AKFireMedic
Status: offline
Looks great Dave! Easy to see is an understatement!
On another note, did you use 1 or two elevator servos on her and how did it balance with the setup you used? Thanks.
Da** it feels good to be a Pro Bro
(in reply to Jeffro)
       Post #: 6
RE: 67" Fusion ARF/ recovered and maiden ready - 4/2/2008 3:22:17 AM
daveopam
Status: offline
I used two elev servos. I slid the engine back quit a bit. I did not want to take the velocity stack off the carb. So I rounded out the fuse enough so about 1/2 of the stack is recesed. Even with the stack off I would have to round out some. The carb opening would be very close to the fuse side. So I left it on and did the best I could. I will put a pic up later. I am using a 5 cell NiMih pack and have it in the trailing edge of the wing behind the hatch opening. With this set up my CG is 8-3/8" back at the root from the LE. This looks to far back to me but the book says 8" to 8-1/2". So I am in the range. Also notice I have no spinner and a very light prop. My 52" flys better when the fuel is less than half. If this 67 is the same I may cut a hatch in the fuse and move the battery back. Only time will tell.
David
(in reply to AKFireMedic)
       Post #: 7
RE: 67" Fusion ARF/ recovered and maiden ready - 4/2/2008 8:51:05 AM
Spacey
Status: offline
I like the scheme Dave! I think it looks funky!
       Post #: 8
RE: 67" Fusion ARF/ recovered and maiden ready - 4/2/2008 2:33:50 PM
daveopam
Status: offline
Thanks Spacey.
AK here are a few pics of the tail and engine set up.
david
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Spacey)
       Post #: 9
RE: 67" Fusion ARF/ recovered and maiden ready - 4/2/2008 2:36:21 PM
daveopam
Status: offline
BTW the old scheme is available if someone wants it?!?!?!
David
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 10
RE: 67" Fusion ARF/ recovered and maiden ready - 4/3/2008 1:52:13 AM
AFSalmon
Status: offline
quote:
ORIGINAL: daveopam
David
haha, looks like the snake has shed its skin for a shiny bright and new skin!
Hey Dave that sure looks really nice. You should be proud of a job well done. When you stripped the ARF how did the build look underneath? Did you go ahead and check it out while she was naked? hehe. Run some thin CA around anything you don't like. I do this on all my ARFs regardless of what brand. I'm going through a 102" QQ Yak right now getting it ready for my son to fly. Almost done!
Mike
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
       Post #: 11
RE: 67" Fusion ARF/ recovered and maiden ready - 4/3/2008 3:11:30 AM
daveopam
Status: offline
Mike I did go over it front to back. The plane was put together very well. There were a few soft area. The ply circles that reinforce the anti rotation pin holes needed more glue along with the two rings with the blind nut installed. There was also a small gap in the ply in the front of the fuse in front of were the canopy are is. Other than that it was very nice and I am picky. I did run some thin here and there but not becouse I thought some areas needed it. I just thought it would be foolish not to while it was naked.
Thanks for a great product.
David
(in reply to AFSalmon)
       Post #: 12
RE: 67" Fusion ARF/ recovered and maiden ready - 4/3/2008 10:27:52 PM
STLPilot
Status: offline
Yet another TMPro success story.
Here At The Wall
       Post #: 13
RE: 67" Fusion ARF/ recovered and maiden ready - 4/4/2008 12:02:10 AM
