gboulton
TN, USA Status: offline
Robert, Hopefully you'll take this not as a "slam", but as enlightenment. I believe you're using the term "Angle of Attack" incorrectly. I THINK you MIGHT mean Angle of Incidence, but I'm not sure...so, I'll put the question to you after a brief explanation. Angle of Attack is the angle the wing makes with the "relative wind"...the oncoming "wind" made by the airplane as it moves through the air. Think abouot a plane that is moving straight ahead, in level flight, neither gaining nor losing altitude. If it's doing so with its nose up high, that's a "high an angle of attack". If it's doing so with its nose down lower, it's a "low angle of attack". Angle of Attack is ENTIRELY dependent upon (and is in fact DEFINED by) the angle the wing makes with ONCOMING AIR. In short, for there to BE an angle of attack, the plane must be moving. So...it's not likely to be something you can adjust on the ground....since it doesn't exist. *heh* Now, in FLIGHT it is, certainly, VERY easy to adjust...just move the elevator up or down. Angle of incidence (or wing incidence) on the other hand is the angle of a wing's chord (well, technically its lift line, but close enough for a symmetrical wing) makes with the longitudinal axis of the plane. In other words, if the plane's fuselage was sitting perfectly level, what angle is the chord of the wing at in relation. This, obviously, is precisely the sort of thing one can adjust on the ground. Now...while it's accurate to say it'll make NO difference, it's not LIKELY that the wing incidence is causing your issues, unless it's WAY WAY off. For all PRACTICAL purposes, its an angle that doesn't matter a whole lot in flight. Its most notable area of impact would be during take off. da Rock makes excellent points...a pitch sensitive aircraft is USUALLY due to either a CG that is too far rearward (depending on the model, even a 1/4" can make a notable difference", or too much elevator travel. As he pointed out, since you did not specify the model type, size, or the throws you're using, it's hard to say which of those might be the issue.
_____________________________
The free man will ask neither what his country can do for him nor what he can do for his country. - Milton Friedman
