DarZeelon
Joined: 4/9/2003 From: Rosh-Ha'Ayin, ISRAEL Status: online
Hugh, Yes, this discussion can go on for ever and ever. I agree with you about the fact that after break-in is completed, tapered-bore engines can be run, without any limitation, at a four-cycle rich mixture setting. I have written it specifically in the tapered-bore break-in thread. But even the C/L flyers, who regularly fly at four-cycle settings, should and actually do the break-in, at a rich two-cycle setting. However, about the generically written OS manual, telling you to do the break-in alternating between two-cycle and four-cycle; it has been specifically contradicted by AnnMarie Cross and by Bill Baxter, of the US rep for OS, Hobby Services. Even the OS Q&A (question #2), in the web site specifically tells you not to break-in their ABN engines, at a four-cycle rich setting. It also tells you that the fuel must contain some Castor oil. So if you stand by the OS manual, insisting it is correct; you are also contradicting the OS 'brass' (not the B in ABN...).
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com MVVS - Jett - Nelson - Bolly - Mejzlik
