xxxtcr
AZ, USA Status: offline
you could fill the two holes up with silicon, or I think you can get a 257 carb for about 50 bucks, maybe even cheaper if you look around, There is no need for a choke really, Just put your finger over the hole, pull twice, and the carb is primed, will fire on the 3rd pull. But I would strongly reccommend the big bore carb, you will be impressed by the extra power, and if you want to keep the venom motor, you can buy a lightened piston and ported cylinder for about 150 bucks, and have a 4.5 hp motor and then throw a pipe at it and you'll be doing great, I would suggest another prop though, My dad found some aluminum tubing that worked great as a shim, I will find out where he got it from, you can stuff any 1/4 in prop with it and make it work on the smaller shafts.
