subsinker
IL, USA Status: offline
Tow, As you know, these engines are really basic. No distributor, no camshaft timing, valve lash or settings, nothing like that. So, if the engine was running and will not start the first place I would look at is either fuel system or ignition. I know that sounds simple but it can drive you crazy,too. Assuming something majorly catastrophic didn't happen to the engine (burning a piston, seizing it, hydrolock, etc. Check to see if you have a good strong spark. The coil can go bad and still have a weak spark. You will know when you check it if its ok or not. Make sure your coils is not grounding out somehow, maybe a wire rubbing up against something. Check your plug to see if its ok, not running rich or lean, check to see if its wet. Assuming you do all that and still no soap, it is a fuel problem, plain and simple. Take a good look at your fuel lines, make sure that they are not pinched somewhere and you are getting fuel. An easy way to check is to take the fuel lines off, blow into the pressure fitting and see if you have a steady stream of gas coming out. (be sure your somewhere where fumes are not a problem, though) If, you have a steady stream of gas then take a look at the carb. Is it on tight, does the gasket look ok, is there a possibility of dirt in the carb (it only takes a speck of something to shut these engines down RIGHT NOW. I would probably disassemble it and clean it all out. They are not difficult and it sounds like you have probably done it a few times. If all else fails, go right back to square one with the settings. I keep a record (written) of all of my gas boats settings, fuel type, oil mixture, etc so I can go back if something goes wrong. I guess I get that from my open wheel racing days. Hope this helps, Pete
_____________________________
There are two types of ships: submarines and targets
