RE: New GAS Boats from Venom!!
Tower Hobbies
Logged in as Guest
Users viewing this topic: dtacmed, Foggo
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> RE: New GAS Boats from Venom!! Page: <<   < prev  42 43 [44] 45 46 47 48 49 50 51   next >   >>
Login
RE: New GAS Boats from Venom!! - 7/31/2009 9:02 AM
Watsy
Score: 100
Last Login: 3/7/2010
Status: offline
well my OMEN RACING zenoah is on its way. modded to 5hp from hobby supplies....
Hide Signatures
(in reply to Canadian LoCo)
       Post #: 1076
RE: New GAS Boats from Venom!! - 8/9/2009 3:21 PM
Hi8iS
Score: 100
Last Login: 3/20/2010
Status: offline
Hello everyone I have the Segad Hull. I bought a damaged hull & am fixing it & plan on turning it into electric. I need a dual pickup rudder. I am a newby when it comes to building boats & was wondering if this rudder would work good. I read earlier in this thread that some of you just replaced the rudder & used the stock mount, but I don't have the stock mount so I was wondering how much of a standoff would be recommended. If this rudder will hang off the back back of the boat to far can someone recommend what would be right? thanks.
http://cgi.ebay.com/RC-GAS-BOAT-5-IN-Rudder-kit-with-2-water-pick-ups_W0QQitemZ350237056529QQcmdZViewItemQQptZRadio_Control_Parts_Accessories?hash=item518bc15e11&_trksid=p4634.c0.m14.l1262
Hide Signatures
(in reply to Watsy)
       Post #: 1077
RE: New GAS Boats from Venom!! - 8/9/2009 3:33 PM  1 votes
Ron Olson
Score: 1135
Status: online
That might be too much stand-off. Bill also has this one on his site for the same price: http://topsecretboats.com/inc/sdetail/196 . He's great to deal with BTW, I've bought a few things from him.
_____________________________
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
(in reply to Hi8iS)
       Post #: 1078
RE: New GAS Boats from Venom!! - 8/9/2009 7:38 PM
xxxtcr
Score: 100
Last Login: 3/15/2010
Status: offline
use the stock standoff and get a rudder from rocket city racing, THe one pictured will be way too much and will make the boat torque roll easier, Are you doing twin electric or single?
Hide Signatures
(in reply to Ron Olson)
       Post #: 1079
RE: New GAS Boats from Venom!! - 8/9/2009 10:46 PM
Tow Cobra
Score: 100
Last Login: 3/18/2010
Status: offline
I found a simple drip watering system from home depot just as was suggested earlier in the thread (found it in the irrigation section). I use a small piece of the tubing and then the hose connection section to connect this to the garden hose. Works great to clear out the cooling system after running in salt water. I would definitely suggest this over an aquarium pump.
Also, I now have the spectrum Marine specific receiver and had to buy one of the new DX3s transmitters to use with it. The new marine receiver from spectrum is not compatible with older spectrum surface transmitters from what I've read so a new transmitter was in order for me.
So far it works (unlike my DX3r and surface receiver which cut out and went into fail safe at about 100 yards). I haven't pushed the distance yet but my trial usage went fine on the water.
Hide Signatures
(in reply to xxxtcr)
       Post #: 1080
RE: New GAS Boats from Venom!! - 8/10/2009 1:55 AM
brians63
Score: 100
Status: offline
has anybody moved there fuel tanks from the left side to the middle an how did you do it? i clipped the zipped ties an moved it over to get an idea of how it will sit an found out it doesn't sit flat so i am trying to figure out how to mount it in there without it moving side to side..
Hide Signatures
(in reply to Tow Cobra)
       Post #: 1081
RE: New GAS Boats from Venom!! - 8/10/2009 10:09 AM
Hi8iS
Score: 100
Status: offline
quote:
ORIGINAL: xxxtcr
I looked on Venoms website & they don't sell the standoff seperately. I just don't want to spend 62 on the stock rudder assembly & have to ditch the blade it came with just to replace it. I plan on using a single brushless motor. I'm pretty new to boat building & am still trying to figure out what kind of motor/esc I will use. Im only looking to go 45-50 as from what i've read the boat is better suited at these speeds. i will try to find a electric motor/esc that can provide me with about 4 hp.
Hide Signatures
       Post #: 1082
RE: New GAS Boats from Venom!! - 8/11/2009 7:09 AM
Watsy
Score: 100
Status: offline
looking at putting a 1/4 drive on to the KOS strut,flex ect . has anyone done this? if so can u tell me what parts you used and where from. any links would be great.
Thanks, Watsy
Hide Signatures
(in reply to Hi8iS)
       Post #: 1083
RE: New GAS Boats from Venom!! - 8/21/2009 9:43 PM
Lee Racing
Score: 100
Last Login: 10/26/2009
Status: offline
I have a KOS on the way and i'm thinking of upgrading the engine.  I've done alot of research on the kWA 4.5, Zenoah G26 mod, and the Sikk 27cc engines.  Im pretty sure i'm going to go with eiher the KWA 4.5 or the Sikk 27cc.  I've heard the sikk doesn't directly bolt up, but how difficult would it be to install.  Could you use the engine mounts off the stock motor?  Looking at the pics of the KWA, and the Sikk 27cc, it looks like they both come with the same engine mounts, but the KWA is supposed to slide right in.
Also has anyone done any mods to the Sikk 27cc?  What kind of hp can you get out of it?
Hide Signatures
(in reply to Watsy)
       Post #: 1084
RE: New GAS Boats from Venom!! - 8/25/2009 12:12 AM
brians63
Score: 100
Status: offline
Does anybody know if they have a belt starting setup or like the Sullivan TigerDrive starting system and handheld starter for these motors?
Hide Signatures
(in reply to Lee Racing)
       Post #: 1085
RE: New GAS Boats from Venom!! - 8/25/2009 3:20 AM
TheRook76
Score: 100
Status: offline
quote:
ORIGINAL: brians63
Yes I have. You must zip tie the side that makes it sit flat. Then zip tie the following side.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Got Adrenaline?
Hide Signatures
(in reply to brians63)
       Post #: 1086
RE: New GAS Boats from Venom!! - 8/25/2009 3:26 AM
TheRook76
Score: 100
Status: offline
quote:
ORIGINAL: Watsy
Thanks, Watsy
Yes I have also. Go to rocket city racing website. That's where you'll find the DPU Rudder with dual pickups and a .250 flex shaft, .250 strut assembly, and .250 drive dog with prop nuts.
http://www.rocketcityracing.com/
Click for fullsize
Click for fullsize
Got Adrenaline?
Hide Signatures
(in reply to Watsy)
       Post #: 1087
RE: New GAS Boats from Venom!! - 8/29/2009 7:06 AM
Justaddwata
Score: 212
Last Login: 3/21/2010
Status: offline
Just a reminder - if you want to sell items - this is NOT the forum to do it in.
Please use the (free) classified section of the site or contact the member directly.
One of the best gas boat picture sites - http://imageevent.com/justaddwata
“If you lend someone $20 and you never see that person again, it was probably worth it...”
Hide Signatures
(in reply to TheRook76)
       Post #: 1088
RE: New GAS Boats from Venom!! - 8/29/2009 4:38 PM
TheRook76
Score: 100
Status: offline
I didn't really notice an increase in performance cause I never ran the boat in stock form. I upgraded the parts and then went out. I couldn't do a comparison.
< Message edited by Justaddwata -- 9/10/2009 5:13 AM >
Got Adrenaline?
Hide Signatures
(in reply to rheeder218)
       Post #: 1089
RE: New GAS Boats from Venom!! - 8/29/2009 6:34 PM
JetJocky
Score: 100
Last Login: 8/29/2009
Status: offline
1st Post here. Has anyone experienced range problems with the radio setup from Venom? I'm considering switching to Futaba for both range and a fail safe. I converted my Segad to Electric. Have not done a GPS read but it is really fast. I'm using a NEU 2230 Motor, Castle 240HV speed control, and 4- 5s 5000 mah lipos. I'm pretty sure it is in excess of 60MPH since it is running at about 30,000 rpm. It is a little unstable in rough water at speed, but still very manageable.
I'm thinking my electric setup may be causing a little interference causing range issues. As long as I keep it close (within 100 yds or so it is fine. Outside of that it seems to have a delay. Having flown model jets and Giant Scale the radio just does not "feel" right.
Glenn
Glenn Hoffman
Glenn_hoffman@sbcglobal.net
Hide Signatures
(in reply to Watsy)
       Post #: 1090
RE: New GAS Boats from Venom!! - 8/29/2009 9:15 PM
NitroSS
Score: 100
Status: offline
Think I am going to just get the KWA engine and the voodoo prop thats mentioned in here. But I kind of wish I had the smaller KOS electric boat for the smaller pond here at home. That dual drive setup on it looks neat
H9 Spitfire Mk II/Saito,H9 P-51D Mustang/Evo.46, ParkZone F4U Corsair,TRX Revo/3.3,Venom KOS/KWA,Aeromarine Spritcat CMB 67
Hide Signatures
(in reply to JetJocky)
       Post #: 1091
RE: New GAS Boats from Venom!! - 8/29/2009 11:36 PM
goodson
Score: 100
Status: offline
please somebody help this guy. his boat is slower than my stock Zen Rio, and i put mine together by guesswork. its kinda sad.
anyone suggest a better carb? his boat seems like its stuck running at the lower RPM range with his carb on there. anything to upgrade to from stock. suggest any place who might make one to fit the stock engine (without seeming like a classified ad....)?
Hide Signatures
       Post #: 1092
RE: New GAS Boats from Venom!! - 8/30/2009 12:50 AM
TheRook76
Score: 100
Status: offline
quote:
ORIGINAL: thegoodson
Well yeah go to this link and you can upgrade to a walbro 257 or 813 carb. They bolt up to the engine but you might have to use their throttle cable system. Scroll half way down the page and you'll see the carbs. They range from 40 to 55 bucks.
http://bonzisports.com/zenoah/zenoah_parts.html
Got Adrenaline?
Hide Signatures
(in reply to goodson)
       Post #: 1093
RE: New GAS Boats from Venom!! - 9/1/2009 4:25 AM
TheRook76
Score: 100
Status: offline
Ok so I just sold my KOS and I was wondering as I never did a comparison to the stock form. I use to run it in choppy bay water and in a lake to help flush out any salt water. I never had any other boats so it seemed quick to me. The new owner says it doesn't seem to get to full throttle in the water. On the table the motor screams and you can see the throttle fully open. Needles are set to 1 1/4 to 1 1/2 turns. Now Bonzi recommended and I bought a 70/15/3 balanced, sharpened prop. I see everyone uses a 67/17/3 prop. How much power does that big prop kill and will it give it that effect of not reaching it's full potential. Thanks guys in advance
Got Adrenaline?
Hide Signatures
       Post #: 1094
RE: New GAS Boats from Venom!! - 9/1/2009 1:00 PM
rheeder218
Score: 100
Last Login: 3/8/2010
Status: offline
quote:
ORIGINAL: TheRook76
sounds like the same problem i was having wiht my boat.
Its not the pro pmy buddy has the same exact boat and its nite and day, to what mine and his run. I put his carb on my boat and it made a big difference. I still think his is stil lputting out more power.
Hide Signatures
       Post #: 1095
RE: New GAS Boats from Venom!! - 9/1/2009 7:06 PM
witespy
Score: 100
Status: offline
I am the new owner. (of therook76 kos) The problem is that I get no Throttle. It feels like it wants to take off.   I checked over everything and found a huge air leak/bubbling gas between the carb. and the engine.
looks like a re- seal will get her up and going again.
Click for fullsize
< Message edited by witespy -- 9/1/2009 7:51 PM >
Hide Signatures
       Post #: 1096
RE: New GAS Boats from Venom!! - 9/1/2009 7:27 PM
TheRook76
Score: 100
Status: offline
Whitespy email sent.
Got Adrenaline?
Hide Signatures
(in reply to witespy)
       Post #: 1097
RE: New GAS Boats from Venom!! - 9/1/2009 7:53 PM
hibby
Score: 165
Status: offline
witespy, Make sure you check your isolator block that it isn't warped, those plastic ones are good for that. Recommend an aluminum one with teflon gaskets. hibby
Hide Signatures
       Post #: 1098
RE: New GAS Boats from Venom!! - 9/1/2009 8:16 PM
rheeder218
Score: 100
Status: offline
if there was a leak then you would have had a "run away" problem when no under load. DId you?
Hide Signatures
(in reply to hibby)
       Post #: 1099
RE: New GAS Boats from Venom!! - 9/1/2009 8:35 PM
witespy
Score: 100
Status: offline
Yes, It did start to run away from me, when I started it up.  I knew something was wrong, so i killed it pretty quick.
hibby , can you point me too that alumimum  isolator with teflon gaskets??
thank you guys
paul
Will this work? I heard that they hold more heat. this true?  http://www.rocketcityracing.com/product_details.php?category_id=117&item_id=944
cool beans.. @ TheRook76 . he is ordering me sharpen prop and everything. what an awseome seller. thank you thank you. I now own his kos. yay! I call the TUG, if you ever want to sell it =P
edit: .Good call on the iso. Looks like that is the problem. warped Bad.  This is from over heating ?
edit edit: I ordered the part from WHH. two days later and they have not shipped my parts let. The site seems like they have a weak shipping department. They are close on friday. monday is a hoilday. who knows when I'll see them. I do not think I will never order from them again, and i live in FL. (ordered again from rocket racing, and its already on the way.)  http://www.rocketcityracing.com/product_details.php?category_id=24&item_id=252
quote:
ORIGINAL: rheeder218
Click for fullsize
Click for fullsize
< Message edited by witespy -- 9/3/2009 5:13 PM >
Hide Signatures
       Post #: 1100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.328RCU1
