Heli-Max is recalling the GPMP0401 Lithium Polymer Battery Pack
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> Heli-Max is recalling the GPMP0401 Lithium Polymer Battery Pack
Page: [1]
Login
Heli-Max is recalling the GPMP0401 Lithium Polymer Batt... - 4/4/2008 1:40:01 AM
PSXBatou
Status: offline
FYI
quote:
Heli-Max is recalling the GPMP0401 Lithium Polymer Battery Pack included with the Axe CP-L Helicopter (HMXE06**) purchased between November 2007 and April 2008. Heli-Max has determined that in some cases the battery pack may pose a fire hazard. Customers are advised to IMMEDIATELY STOP USING THE BATTERY PACK and follow the instructions below to return it and obtain a free replacement.
http://www.helimax-rc.com/batteryrecall/
_____________________________
TRF-416 | TA-05MS | TT-01 | RC10 B4 Factory Team
AXE CP-L | Blade 400
       Post #: 1
RE: Heli-Max is recalling the GPMP0401 Lithium Polymer ... - 4/4/2008 3:51:24 AM
BigTruckDriver
Status: offline
Theres a fire hazard with every li-po on the market you cant leave it overnight.
If it isn't broken,adjust it till it is.
(in reply to PSXBatou)
       Post #: 2
RE: Heli-Max is recalling the GPMP0401 Lithium Polymer ... - 4/4/2008 4:38:44 AM
rcowboy
Status: offline
I bought my axe cp-l in jan of 08 and in about a month the lipo was swelling. I wasn't over discharging it either. I also lost alot of performance out of the pack. I sent it back and they replaced it free of charge, but they sent me the one thats currently being recalled for the replacement lol.
(in reply to BigTruckDriver)
       Post #: 3
RE: Heli-Max is recalling the GPMP0401 Lithium Polymer... - 4/4/2008 4:56:37 PM
PilotLight
Status: offline
When I was about to upgrade to Li-po, I made sure to get the lightest battery with the highest C rating and highest capacity I could find. I didn't think the 910 mah batteries were capable of the high amperage draw required to hover this heli. C rating is a multiplier of the batteries capacity, so 10C 910 mah is only capable of 9.1 amps, but with a 1320 its 13.2 amps. The TP's were capable of 15 amps continuous and up to 18 amps burst which I felt was safe. And, I always balance them before, during, and after a charge.
Be sure to take advantage of Helimax's offer to upgrade to the better battery. Its a great offer.
Now, batteries are capable of 25C and 50C bursts, they're safer, but should still be treated with respect.
< Message edited by PilotLight -- 4/4/2008 4:58:41 PM >
(in reply to rcowboy)
       Post #: 4
RE: Heli-Max is recalling the GPMP0401 Lithium Polymer... - 4/4/2008 5:00:44 PM
BigTruckDriver
Status: offline
quote:
ORIGINAL: PilotLight
do you have a part number for the pack you are using? What charger are you using also?
(in reply to PilotLight)
       Post #: 5
RE: Heli-Max is recalling the GPMP0401 Lithium Polymer... - 4/4/2008 5:43:21 PM
PilotLight
Status: offline
OK, here’s what we really need. The stock three and one board should be replaced with a unit that will handle brushless motors. The electronic speed controller on the main motor should also include a battery monitor circuit which would reduce amperage as the voltage decreased to about nine volts. The gyro should be a heading hold gyro which would drive another brushless electronic speed controller for the tail motor. This could all be sold in a package which would include the appropriate brushless motors and heat sinks.
       Post #: 6
RE: Heli-Max is recalling the GPMP0401 Lithium Polymer... - 4/4/2008 5:52:09 PM
PilotLight
Status: offline
quote:
ORIGINAL: BigTruckDriver
I'm using the TP 1320 3s pack.
TP1320-3SPL 11.1V 1320mAh 3-Cell 84 19 x34 x65 49.95 on http://thunderpowerrc.com/html/prolites.html.
The charger I'm using is a Hobbico Quick Field Charger MK II, which will charge 2 packs at once, but is limited to only 1, 2, or 3 Cell packs, no larger. I also have the TP balancer, and an E-sky balancing charger. Finally, I bought some EVO Flight Power 1340 mah packs with 25C rating, but they are a little heavier.
Wish that TP-610C Charger was out when I was looking for a charger. I sound old.
       Post #: 7
RE: Heli-Max is recalling the GPMP0401 Lithium Polymer... - 4/4/2008 10:20:21 PM
Tall Paul
Status: offline
Leaving any Lipo plugged into the charger after it's charged is asking for it.
Leaving any Lipo plugged into the ESC when you're not flying will ruin the Lipo.
Even the ON-OFF switch being OFF won't prevent the ESC from draining the battery below the level it can recover from.
Sparky Paul
http://www.angelfire.com/indie/aerostuff
       Post #: 8
RE: Heli-Max is recalling the GPMP0401 Lithium Polymer... - 4/5/2008 12:46:43 AM
r_william
Status: offline
Great news???
I never thought I experienced the battery performance I have seen others get on YouTube and such.
Soooo, I'm glad for this [recall] and will send all 3 of mine back ASAP!
I'm sure that the arrival of my battery return "envelopes" will coincide with the calmest winds S. Fla. has ever experienced and I, of course, will be GROUNDED!
RWW
(in reply to Tall Paul)
       Post #: 9
RE: Heli-Max is recalling the GPMP0401 Lithium Polymer... - 4/5/2008 2:41:57 AM
Edwinssiv
Status: online
Of course...the 2 lipos I bought are in the recall...grounded with the only one of my two axes flying...lol...guess it's time to get the other one up and running again...on that one I am using the evo light 1340's. Runs great with them.
< Message edited by Edwinssiv -- 4/5/2008 2:44:26 AM >
Blade CX2/Axe CP/ Trex 450 SE v2/Gazaur Mars 480/TRex 500 GF
(in reply to r_william)
       Post #: 10
RE: Heli-Max is recalling the GPMP0401 Lithium Polymer... - 4/8/2008 12:31:09 AM
Shadow99
Status: offline
I've been using the MegaPower 1350mah 11.1v 20C 3 cell Lipo's from Helidirect, they're around 35 bucks a pop, will give a stock AXE CP around 12-16 minute flights, BL motor users get a little less on flight time. They are the biggest BANG for your buck! I've got an array of the 1350mah MP lipo's, (2) 15C's & (4) 20C's.
I'm using (2) of the ALIGN A/C Balance chargers # RCC-4CX, will charge up to a 4 cell Lipo, have a built in fan, and work GREAT for the $55 they cost, once again from HeliDirect.
Another good idea is to change from those "Light-Duty" DEAN's MICRO PLUG connectors to the DEAN's ULTRA PLUGS!!!!
Shadow
"Growing older is MANDATORY... Growing up is OPTIONAL!"
(in reply to Edwinssiv)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
