RE: Himoto suggestion box
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Himoto Racing Support Forum >> RE: Himoto suggestion box
Page: <<   < prev  1 2 3 4 5 6 [7]
Login
RE: Himoto suggestion box - 6/22/2008 5:33:25 PM
{GBI}Harryball
Status: offline
quote:
ORIGINAL: NAMRXB1
But the South African Distributor is well stocked and the friendly and always available .Its just 1600km Away .
Just thought if there is something that breaks at the track I thought that might fit .
Any weak Points that I should know of?
Just so that I could pre Order the Parts!!
check out this setup quid, this is the one i use
http://www.teamxray.com/teamxray/showfile.php?file_id=4461
_____________________________
Sponsered by: ALL ABOUT FUN HOBBIES /ALL ABOUT FUN HOBBIES PRODUCT REVIEWER
(in reply to NAMRXB1)
       Post #: 151
RE: Himoto suggestion box - 6/23/2008 7:39:44 AM
NAMRXB1
Status: offline
Hi QD
Got your mail Thanks.
I buy from Buxs As I do other lines from him as well probably the friendliest Distributor around.
HIMOTO you have chosen one of the best guys in the business.CONGRATS.
Thanks for the tip on the XRAY site been alot of help!!
Will try to get some photos up when I can figure out how.
Regards
Gunther
PS.How About a RXB-1 Thread???
(in reply to {GBI}Harryball)
       Post #: 152
RE: Himoto suggestion box - 6/23/2008 6:17:48 PM
HimotoRacingUSA
Status: offline
Hi Gunther, the rxb1 thread is up bro: http://www.rcuniverse.com/forum/m_7641660/tm.htm
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
       Post #: 153
RE: Himoto suggestion box - 6/24/2008 7:36:14 AM
NAMRXB1
Status: offline
hi
Thanks Alot
Heading Over
(in reply to HimotoRacingUSA)
       Post #: 154
RE: Himoto suggestion box - 6/24/2008 3:16:16 PM
kuppler
Status: online
Gunther,
and if you go to this site....LINK HERE will have the threads of the Himotos......
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
       Post #: 155
RE: Himoto suggestion box - 6/24/2008 8:07:39 PM
wolfwood_is_here
Status: offline
Also said this in a PM, but good to have out in the open. ^_^
For the 16th scale electric vehicles (my awesome new EXB-16 in particular) the chassis isn't really that stiff. I can grab the front and rear shock towers and twist the vehicle by at least a quarter of an inch. While this isn't bad for bashing, it would be nice to have some more rigidity when running on a track.
Would the nitro aluminum chassis plate bolt up with little issue? If it won't then I would suggest an aluminum/carbon fiber chassis for the 1/16th scale electric vehicles, and either an aluminum/CF top plate.
And in the steering department, I have noticed a bit of slop due to the soft spring in the servo saver/bellcrank. Would it be possible to get a bellcrank without the servo saver? A metal geared servo will more than handle any stresses these little guys could dish out, so a built-in servo saver is nice but not necessary in every context.
With some chassis/steering stiffening, and a good aftermarket powerplant, these guys would rock the racing scene. And if my assumption that the wheel hexes are 12mm is correct, you could bolt up 1/10th scale sedan wheels with rally tires on them to give you a wider tire selection, while still maintaining the original looks of the vehicles. ^_^
(in reply to kuppler)
       Post #: 156
RE: Himoto suggestion box - 6/24/2008 8:28:29 PM
HimotoRacingUSA
Status: offline
The wheels are 12mm hex but i dont think the nitro aluminum upper plate would work on it.
(in reply to wolfwood_is_here)
       Post #: 157
RE: Himoto suggestion box - 6/25/2008 4:26:58 PM
Hibityhupla!
Status: offline
Hey Ehroof, have they released the metal 2 speed trannies yet? When are they planning on it? Getting bored of running a single speed but fed up with buying replacement gears..lol Let me know....
       Post #: 158
RE: Himoto suggestion box - 6/25/2008 8:21:28 PM
HimotoRacingUSA
Status: offline
not yet, we have been testing the single speed ones to make sure they are good and other gears dont strip out but we are working on the 2 speed also.
(in reply to Hibityhupla!)
       Post #: 159
RE: Himoto suggestion box - 7/12/2008 8:07:33 PM
{GBI}Harryball
Status: offline
Ok guys, here is a suggestion. I have just finished the rebuild of my RXB-1. There was more broken then what I thought. I think that a screw kit would be nice for each of the models. I know i would buy one. What I found was that some of the screws had broken in the wreck. Anyways, I hope to see this soon.
       Post #: 160
RE: Himoto suggestion box - 7/12/2008 9:15:49 PM
kuppler
Status: online
quote:
ORIGINAL: {GBI}Harryball
im pretty sure there was talk about this.. maybe eddie will chime in on this.....
       Post #: 161
RE: Himoto suggestion box - 7/12/2008 9:41:15 PM
{GBI}Harryball
Status: offline
It would be nice, i had some spare screws, but it isnt pretty lol
       Post #: 162
RE: Himoto suggestion box - 7/13/2008 4:57:55 AM
HimotoRacingUSA
Status: offline
I am working on it guys
       Post #: 163
RE: Himoto suggestion box - 7/13/2008 6:18:32 AM
kuppler
Status: online
See told you eddie was working on it.. HAHAHAHA
       Post #: 164
RE: Himoto suggestion box - 7/31/2008 2:25:01 AM
hooleydog
Status: offline
himoto needs to produce CV UNIVERSAL DOGBONES so you updrade the old ones as most truck have them even my DURATRAX MAXIMUM ST TRUCK has them fitted..
