Showtime 90 hor stab concern
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> TEAM RCU >> TEAM RCU - Mike McConville >> Showtime 90 hor stab concern
Page: [1]
Login
Showtime 90 hor stab concern - 4/4/2008 3:42:20 PM
fastplane
Status: offline
Mike, I am completing the ST 4D 90 and am concerned about the horizontal stabilizer. I never had a plane that the stabilizer was two parts. After following the directions to tap the tube for the 4-40 screw and installing the stabs tightly to the fuse I noticed there is some give up and down with the stab when I move them by hand. It seems this movement will cause some un-desired results when performing aerobatics. Is this by design? How can I get the stab to be stable? Thanks.
       Post #: 1
RE: Showtime 90 hor stab concern - 4/7/2008 3:03:08 PM
MMcConville
Status: offline
Some wobble ca happen with stab tubes because of the smaller contact area. The easiest fix is to brush a thin coat of finishing resin into the socket in the fuse to tighten the fit on the alum tube. Its very easy to do.
_____________________________
Mike McConville
Horizon Hobby
(in reply to fastplane)
       Post #: 2
RE: Showtime 90 hor stab concern - 4/7/2008 6:42:03 PM
fastplane
Status: offline
Thanks Mike for the help. I am not sure what finishing resin is. I have some resin for epoxy but it never dries.
The tubes seem to be tight but I suppose they could have a tighter fit.
The movement I notice is at the stab to fuse junction. I was careful to minimize space between both stabs and fuse but still a slight space.
My main concerns are:
1. Movement will interfere with aerobatic flying
2. Air flow will make any movement worse in time by wearing down the wood on the stab and fuse.
(in reply to MMcConville)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU2
