RE: E-Smart 600 thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> RE: E-Smart 600 thread
Page: <<   < prev  1 2 [3] 4 5 6 7   next >   >>
Login
RE: E-Smart 600 thread - 4/23/2008 9:01:13 PM
rcmiket
Status: offline
Keep the King. Its really handy to have around. I still mess with mine every chance I get and I can fly it here at home. These bigger ones require lots of space. Its worth more to you than you might think. Mike
(in reply to flyinsolo11)
       Post #: 51
RE: E-Smart 600 thread - 4/23/2008 9:18:38 PM
flyinsolo11
Status: offline
I really wish I could mike, but I need the money- can't have both.
_____________________________
Flying is the art of throwing yourself at the ground... and missing.
(in reply to rcmiket)
       Post #: 52
RE: E-Smart 600 thread - 4/23/2008 10:22:46 PM
rcmiket
Status: offline
Money the downfall of all of us. Good luck I would try E Bay but you need to understand its never worth what you have in it. Good Luck Mike
       Post #: 53
RE: E-Smart 600 thread - 4/23/2008 10:44:51 PM
rcmiket
Status: offline
Actually got some work done on this thing. Mounting the servos was a pain in the a$$. Gyros in everything going the right way radio wise. Now the hard part cleaning up the wiring, mounting the electronics to balance, tracking and pitch adjustment then the test hop. Getting closer buy the day. Mike
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 54
RE: E-Smart 600 thread - 4/23/2008 11:38:49 PM
nuttcaze
Status: offline
I'm jealous, I'm waiting on the last few parts, mainly a set of calipers so I can do some measuring on my links before trying to install those PIA's, they have some good starting points over there, but I'm sure you already saw them
       Post #: 55
RE: E-Smart 600 thread - 4/24/2008 12:04:23 AM
rcmiket
Status: offline
I checked the all with my calipers re-sized the links and so on. When it came to final assembly there was still some work to do to get them all square. I thought I had it but when I needed to change some of the setting in the radio I had to do some work with the "sub trims" I normally don't like to do that since I set everything up 90 degrees but it just didn't work out that way this time. Putting the servos in is a real pain but it can be done. Tomorrow after work I'll mount the motor set the pinon and maybe spool her up for the 1st time. I know your concerned about your servo chose but you should be fine if all set set up correct and running smooth. I just would not push those servos to hard. Mike
(in reply to nuttcaze)
       Post #: 56
RE: E-Smart 600 thread - 4/24/2008 12:12:44 AM
nuttcaze
Status: offline
nope, just wanna hover it, then I'll be happy , just got back from flying my HBK II down at the park, theres dead bugs all over my rotor blades
       Post #: 57
RE: E-Smart 600 thread - 4/24/2008 10:37:02 PM
rcmiket
Status: offline
Now this is weird. Got everything set up yesterday and was getting all the stuff mounted and secured, everything nice and tidy (almost too nice and tidy for me). Turned on to check everything and one of the servos is dead, pulled out the spare and it works so the servos died overnight. I need to figure a better way of mounting these servos because it a major Pain In The A$$ to pulled and replace them. I did get the motor mounted and spun it up a bit without the main blades, very impressive. I'm still looking at this weekend if all goes well. Mike
       Post #: 58
RE: E-Smart 600 thread - 4/24/2008 11:27:08 PM
flyinsolo11
Status: offline
How does a servo 'die' overnight?
       Post #: 59
RE: E-Smart 600 thread - 4/25/2008 12:10:17 AM
rcmiket
Status: offline
I'm going to take it apart and see. My guess it a loose wire or something stupid. Better on the bench than in the air.
       Post #: 60
RE: E-Smart 600 thread - 4/25/2008 2:09:33 AM
flyinsolo11
Status: offline
Gotcha- if you can, let us know what you find.
       Post #: 61
RE: E-Smart 600 thread - 4/25/2008 9:05:59 PM
rcmiket
Status: offline
Talked to the LHS and hes a good guy. He offered to send the servo in for repair ( nice because I really want to know what the deal is with it) If I take it apart it voids any warranty ( even tough I got it on E Bay hes still sending it in). I Replaced it and everything is working great. I need to track the blades and set pitch but I'm finished . Here are the end results. If the wind don't stop I'll test hop it Sunday at a friends warehouse. We will see. Mike
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 62
RE: E-Smart 600 thread - 4/27/2008 1:08:25 AM
rcmiket
Status: offline
OK balance seems to be a issue here. With my 5S pack I'm going to need some sort of extension on this to get it to balance. I have no idea how these guys are shoving 4 3S packs into the battery holder and get it to balance. I've got several ideas as what to do but the test hop is postponed till I get it balanced right. Mike
       Post #: 63
RE: E-Smart 600 thread - 4/27/2008 1:54:54 AM
rcmiket
Status: offline
Finished product less the battery tray mod. I'll have it figured out by Monday. Mike
Click for fullsize
Click for fullsize
       Post #: 64
RE: E-Smart 600 thread - 4/27/2008 2:28:29 AM
flyinsolo11
Status: offline
Awesome- bummer about the problem...
Just out of curiosity mike, what is your ability level w/ helis?
       Post #: 65
RE: E-Smart 600 thread - 4/27/2008 6:21:33 AM
