Gizmo-RCU -> RE: Piston Damage (4/9/2008 3:34:16 PM)
I agree with Buzz, I would not waste the time, you will end up with a suspect engine no matter. There may be other damage to the crankcase bottom end that does not show, yet. The damage to the rod end likley came from something pushing the steel ball into it at high speed, perhaps wedging against the crankcase momentairly or some other part? I have worked on many engines in my life time, gas, diesel, 2 stroke and 4 stroke small engines and many glow engines. With that type of damage I wouldn't waste my time, unless I just wanted to see if I could do it. I doubt that it will be as good as it previously was and may not last long. Typical for my projects like this.[;)]
