Remklep
Joined: 12/10/2007 From: Haarlem, NETHERLANDS Status: online
quote:
ORIGINAL: SMUGator My opinion is that if you were hand-cutting this kit, you would be extremely fortunate to get as close as the tolerances you list above. I think you will be just fine going with those thicknesses. My $0.02 only. Tom As I'm using a cnc-router to cut the kit, which is accurate to 0.01 mm, I thought it might pose a problem, but you guys are right, 0.35 mm difference is not that much. So I decided to not modify the drawings. Thanks for your opinions, Tom and Chad. Cheers,
_____________________________
Danny "Remklep" Busch Its better to beg for forgiveness, than to ask for permission.
