RE: 1/6 Scale F4U Corsair Group Build
Tower Hobbies
Logged in as Guest
  Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $99.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: 1/6 Scale F4U Corsair Group Build
Page: <<   < prev  13 14 [15] 16 17 18 19 20 21 22   next >   >>
Login
RE: 1/6 Scale F4U Corsair Group Build - 6/2/2008 11:38:16 PM
rwright142
Status: offline
I got mine and am working on it. I like what you have done with the kit - very nice.
_____________________________
In the works: 1/6 Scale F4U Corsair
(in reply to Chad Veich)
       Post #: 351
RE: 1/6 Scale F4U Corsair Group Build - 6/3/2008 1:13:22 AM
WhiteRook
Status: offline
wow , these are some GREAT threads, i'm going to spend some time here i can see
rock on
(in reply to rwright142)
       Post #: 352
RE: 1/6 Scale F4U Corsair Group Build - 6/3/2008 10:06:45 PM
Remklep
Status: offline
A little progress report.
Today I started on the horizontal stab and elevators.
A tricky thing to get right is the 0.4 mm (1/64" ) recess along the entire lenght of the horizontal stabilizer.
I did it by clamping a straight piece of wood to the top of the sheeting and using my aluminium T-bar sander, with a piece of the same thickness as the sheeting under it for support, carefully sanding and measuring until I had sanded 0.4mm off.
The pictures will explain it better:
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Remklep -- 6/3/2008 10:31:45 PM >
Danny "Remklep" Busch
Its better to beg for forgiveness, than to ask for permission.
(in reply to WhiteRook)
       Post #: 353
RE: 1/6 Scale F4U Corsair Group Build - 6/3/2008 10:09:37 PM
Remklep
Status: offline
Then I planked the horizontal stabilizer on both sides.
I also increased the balsa blocks for the Robart hinge points in size and sanded them flush so they would also be glued to the top and bottom sheeting:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Remklep)
       Post #: 354
RE: 1/6 Scale F4U Corsair Group Build - 6/3/2008 10:21:06 PM
SMUGator
Status: offline
quote:
ORIGINAL: Remklep
A tricky thing to get right is the 0.4 mm (1/64" ) ridge along the entire lenght of the horizontal stabilizer.
Hi Danny,
I made myself a little tool to sand those insets for the hinge gap covers from an old leftover landing gear mount block. If you build the sandpaper up to exactly 1/64 of an inch and cover half the block, it acts as a sanding tool with a built-in depth gauge. When the wood block bottoms out and the sandpaper stops cuttting, then you know that the cut-out is the correct depth. I first saw this posted on here a couple of years ago by "tubig" so I call it the tubig sander. I found that a smaller one is nice to have as well when I do the curved trailing edge on the Corsair wing.
Tom
Click for fullsize
Click for fullsize
Click for fullsize
Currently building a 1/6 Scale F4U-1A Corsair (BuNo 17777) and finishing a TF 1/8 Corsair
       Post #: 355
RE: 1/6 Scale F4U Corsair Group Build - 6/3/2008 10:34:41 PM
Remklep
Status: offline
Thats also a very nice way to do it Tom.
I think I will use your method when I can't clamp the sheeting to the building board, thanks for the tip.
Cheers,
(in reply to SMUGator)
       Post #: 356
RE: 1/6 Scale F4U Corsair Group Build - 6/3/2008 11:11:31 PM
Chad Veich
Status: offline
quote:
ORIGINAL: SMUGator
Hi Danny,
Tom
This is how I do it as well. I usually sink the hinge gap cover a fraction more than necessary and then sand the sheeting down to match it perfectly.
       Post #: 357
RE: 1/6 Scale F4U Corsair Group Build - 6/4/2008 4:55:28 AM
rustypep
Status: offline
Thanks for the update on the kits Chad. I look forward to seeing these parts and what you do next. I have used the same trick for the hinge gap tool and it really works great.
Club Saito Member 354
       Post #: 358
RE: 1/6 Scale F4U Corsair Group Build - 6/4/2008 11:25:42 PM
Chad Veich
Status: offline
James and Gene, your tail kits are on the way. Rusty, yours is done except for the 1/64 ply parts. I ran out of ply and had to re-order so it will probably be a week or so before I can get it done and shipped. Two more to go! Thanks guys and I hope you're all satsfied with the kits.
       Post #: 359
RE: 1/6 Scale F4U Corsair Group Build - 6/5/2008 3:36:43 AM
SMUGator
Status: offline
Rather than messing around any more with brazing my elevator and rudder torque rods and control arms, I thought I might just order them for a few bucks each from existing kit's replacement parts list. I'll do a single servo on the elevator and pull-pull on the rudder. I'll be building these bits from the Royal plans, so dimensions aren't super critical. Any recomendations on a good kit to "poach" from? I thought of the TopFlite 1/5, but it looks like the elevator halves may have independent control horns?
Tom
       Post #: 360
RE: 1/6 Scale F4U Corsair Group Build - 6/5/2008 7:39:27 AM
DaddySam
Status: offline
Chad
The kits arrived today and look great. My son and I will start buidling in the next few weeks.
Tom
I wonder if there might be a builder here who is good at brazing? I'm probably going to use a steering arm from a nose gear and just file a flat on my joiner wire, slide the steering arm on, use red loctite to lock the threads on the set screw into place, and then make the two bends. If the steering arm is bulky at the attachment site, I can just create a some space by cutting some balsa away. I think that area is all hidden anyway.
Sam
       Post #: 361
RE: 1/6 Scale F4U Corsair Group Build - 6/5/2008 8:45:23 AM
SMUGator
Status: offline
quote:
ORIGINAL: DaddySam
Sam
Would be nice if that were the case. I'm willing to learn if someone can teach as well. I got a couple of tips regarding using wheel collars and the like the last time this subject came up, and never got happy with the results. I give everything the old "can I break this?" test. I think the right answer is a steel control horn brazed to a music wire torque rod. If I can't figure out how to do that pretty quickly and easily, then I'm more than happy to buy it. Hate to invest too much effort in a bit that I need about every two years. I do need it pretty soon though as I build that part integral to the elevators and rudder early in the process.
Tom
< Message edited by SMUGator -- 6/5/2008 8:59:52 AM >
(in reply to DaddySam)
       Post #: 362
RE: 1/6 Scale F4U Corsair Group Build - 6/5/2008 4:18:34 PM
Chad Veich
Status: offline
I will speak to my father about making up the elevator wire joiners. He has been a fabricator all his life and he's made lots and lots of elevator joiners for me. I've not broken one yet!
Chad
       Post #: 363
RE: 1/6 Scale F4U Corsair Group Build - 6/5/2008 10:46:36 PM
rwright142
