RE: 1/6 Scale F4U Corsair Group Build
Tower Hobbies
Logged in as Guest
  Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $99.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: 1/6 Scale F4U Corsair Group Build
Page: <<   < prev  15 16 [17] 18 19 20 21 22 23 24   next >   >>
Login
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 4:25:35 AM
Tripower455
Status: offline
quote:
ORIGINAL: Chad Veich
Sam and Glenn, your tail kits are on their way. Vic (Redr00ster), if you're out there, I need your shipping address! Anyone have Vic's email addy? Richard and Randy, did you guys get your kits yet?
Chad
Chad,
I found the tail kit at home after being away for more than a week!
Simply beautiful work!
Thanks for your considerable efforts! The parts are better than 99% of the kits I've built in 30 years of RCing....... The plans and CD are over the top and much appreciated....... I can't wait to build it..... I'm gonna try out Mig welding the horn........ I'll have it out tomorrow for something else, so it will be no biggie to try it out......
I have been busy lately with work and my second job (my band), so NO RC stuff at all.... I am going to try to get out to the field with my son tomorrow.....
< Message edited by Tripower455 -- 6/11/2008 4:46:43 AM >
(in reply to Chad Veich)
       Post #: 401
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 6:36:12 AM
Chad Veich
Status: offline
I've begun the process of drawing out the instrument panel and instruments. Just as with my Spitfire panel I will draw a full color graphic of each instrument specific to the Corsair. I realize there may be some variations from one Corsair to the next and we can customize if necessary. Otherwise I will try and do my best to make a panel specific to the F4U-1a. I would also like to get started on a design for the seat but I'm seriously lacking in documentation for that item so any and all help appreciated.
Danny, beautiful job on the joiner wire. Want to make about a dozen more?!!!
Glenn, thanks for the kudos and I'm glad you are happy with your kits. Good luck at the flying field!
(in reply to SMUGator)
       Post #: 402
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 6:43:08 AM
SMUGator
Status: offline
Chad, can you post a (another in case I'm too lazy to scan the thread) link to your Spitfire cockpit build?
Tom
_____________________________
Currently building a 1/6 Scale F4U-1A Corsair (BuNo 17777) and finishing a TF 1/8 Corsair
       Post #: 403
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 8:55:29 AM
p 40
Status: offline
YOU ARE ALL VERY KIND ONES, I UNDERSTAND WELL ENOUGH, I WOULD NOW HAVE NEED OF THE PHOTOS OF THAT THAT YOU HAVE BUILT THIN TO, SO WHEN MI ALSO ARRIVES THE KIT LASER ME MI METTO Á. YOUR PEER AS CONSTRUCTION HI GIANLUCA
       Post #: 404
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 9:33:11 AM
SMUGator
Status: offline
Gianluca, your writing style reminds me of someone else that likes to write in all CAPS, and I can't think of who it is. I think it was timothy something...
< Message edited by SMUGator -- 6/11/2008 10:01:21 AM >
(in reply to p 40)
       Post #: 405
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 9:52:26 AM
Remklep
Status: offline
I will first have to buy a better torch.
The one I'm using is from Proxxon, it uses cigarettelighter-gas as fuel which is just barely hot enough for silversolder.
I used almost 2 full fillings to just make the silver on the elevator-rod hot enough again to start to flow.
So I'm going to look in the DIY shops for a small torch on acetylene and oxygen.
Danny
Danny "Remklep" Busch
Its better to beg for forgiveness, than to ask for permission.
       Post #: 406
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 11:31:22 AM
p 40
Status: offline
EXCUSE ME MA I DON'T KNOW THE ENGLISH USE A TRANSLATOR HI
(in reply to Remklep)
       Post #: 407
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 2:54:35 PM
rwright142
Status: offline
What are you guys using for hinges? If you are going to use Robart hinges what size will you get?
Also, what are you using for the hinge blocks? I have read where some people use balsa and cut the blocks into small sections then glue them together with the grains crossed for added strength.
< Message edited by rwright142 -- 6/11/2008 6:02:34 PM >
In the works: 1/6 Scale F4U Corsair
(in reply to rwright142)
       Post #: 408
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 3:38:20 PM
Chad Veich
Status: offline
quote:
ORIGINAL: SMUGator
Tom
Tom, I don't have a build thread per se for the Spitfire cockpit. The first link below is to the instructions that I provide with the Spitfire cockpit kit which show exactly how it is put together. The second link is to a few pictures of my prototype cockpit parts on a friend's web site. The seat that I make now is vac-formed rather than folded matte board and is much more detailed than what is in these pics. I will be vac forming the Corsair seat in the same manner.
http://s8.photobucket.com/albums/a23/SPITMKV/
http://www.t-birds.be/accessories.htm
       Post #: 409
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 5:23:48 PM
rwright142
Status: offline
Here are some pictures of a seat from the FG-1D being restored in Cincinnati. The tick marks on the measuring stick are in inches. I'm not yet accustom to metric...
Just in case you are interested, this FG-1D flew in the "Baa Baa Black Sheep" movie and the TV show. It was fitted with a smoke system and was the Corsair that was always getting "shot down".
These are some of the pictures from the "Corsair Graveyard" that I visited and that Tom noted in an earlier post. Here is a link if you want to see some other "out of the plane" pictures:
Corsair Graveyard
The last 3 pictures were emailed to me some time ago. I do not recall the source.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by rwright142 -- 6/11/2008 6:04:57 PM >
       Post #: 410
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 8:58:03 PM
Chad Veich
Status: offline
Thanks Richard, those will do nicely. I did visit the "Corsair Graveyard" link but I did not see the seat pics that you posted above among the images. Are they in another of your Photobucket albums or am I just missing something?
< Message edited by Chad Veich -- 6/11/2008 9:00:14 PM >
       Post #: 411
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 8:59:13 PM
p 40
Status: offline
HI CHAD HAI RECEIVED MY MAIL?
       Post #: 412
RE: 1/6 Scale F4U Corsair Group Build - 6/11/2008 9:05:16 PM</
