Chad Veich
AZ, USA Status: offline
quote:
ORIGINAL: Remklep I like the custom building board too, good idea if you have to put it aside for a while to work on something else. I believe I'm gonna ahem, "borrow", that idea from you. Borrow away Danny! I'm building the fuse at work so I needed it to be somewhat mobile so that I can put it away when necessary. Also, I wanted to be sure I had a perfectly flat building surface. quote:
ORIGINAL: p 40 Hi CHAD you have received the message? GIANLUCA I will send you the CAD drawings later today Gianluca. quote:
ORIGINAL: jetfool Chad, Fus. looking great. Does the fin have the 2 degree offset from the centerline? I too want to order a tailkit , hope I'm not to late. I'll send an e-mail. It does not have the fin offset although it would be quite simple to add at this point. I don't think the Royal kit includes the offset either. Please do send me an email regarding the tail kit. cvnkv@aol.com
