Lafayette
Joined: 9/10/2007 From: Geneva, , SWITZERLAND Status: offline
Thank you BMatthews. Maybe you cannot see because of the plans, but the tail area is actually about 12-13 % of the wing area. I thought about the tail surface as well for a long while, thank you for pointing that out straight away. I might change it before printing to be a tiny bit smaller, again thank you. I will go over to my local club and ask if anyone there is any of a scratchbuilder. Maybe it will be easier for them to tell seeing the actual plan. Thank you for commenting. I will go over to my local balsa supplier with my dad next weekend- ahhhh cant wait to start building- and buy all the necessary equipment. I am guessing the workboard along with the knives and glue and the actual balsa and plywood and the aluminum wing tubes-that will all cost quite a penny. I am not too good at economics because I usually build from trash can scrap material, I do not know the average balsa prices. What will you estimate the whole thing- without any radio equipment- to cost if I will buy 2 mm and 5 mm balsa fuse spars, 4 mm plywood spars, 3 aluminum tubes different sizes, a lot of 2 and 3 mm blasa sheets and some 1 mm plywood sheets. Wow, I jsut noticed it is quite a lot, but what will it cost? 90 dollars? 100? Thank you everyone, Yishht.
