Foam combat plane
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Combat >> Foam combat plane
Page: [1]
Login
Foam combat plane - 4/6/2008 4:46:00 AM
fly boy2
Status: online
I am trying to finish building a plane and I would like to build a cheap foam combat plane to help pass the time. Something that can be build in a day or two, and cheap to build . If anyone know of some plans or a link to a site.
_____________________________
Soldier: Those lights are blinking out of sequence.
Murdock: Make them blink in sequence.
       Post #: 1
RE: Foam combat plane - 4/6/2008 5:37:58 PM
yankee samurai
Status: offline
www.jkaerotech.com
Randy Shiosaki
(in reply to fly boy2)
       Post #: 2
RE: Foam combat plane - 4/6/2008 6:41:17 PM
Montague
Status: offline
Also, take a look at TufFlight, they make a number of planes that are designed to really take a beating, and fly quite well.
http://www.tufflight.com/
Kirk Montague Adams
RCCA 560
(in reply to yankee samurai)
       Post #: 3
RE: Foam combat plane - 4/6/2008 10:39:01 PM
batchelc
Status: offline
You can do a search for the FUNK on the forums. Made form 3/4" pink insulation foam. If you want something with a real airfoil I've built a plane with foam core wings and a coro fuse. Cheap and light. I haven't maidened it yet, but I plan to next weekend (travelling a lot lately). I'm planning on offering kits with CNC cut foam core wings for $45 bucks. Let me know if your intersted. Look a few posts back in RC Combat for twin tail SSC design. Chris
http://www.wichitapilot.com
(in reply to Montague)
       Post #: 4
RE: Foam combat plane - 4/7/2008 4:07:23 AM
fly boy2
Status: online
If it does fly which it looks like it will, is there anyway you could shrink the 60'' span to a 30'' or smaller and do you think it could be ran with a brushless motor?
Good Luck with maiden flight.
< Message edited by fly boy2 -- 4/8/2008 3:37:10 AM >
(in reply to batchelc)
       Post #: 5
RE: Foam combat plane - 4/15/2008 2:23:11 AM
batchelc
Status: offline
Fly boy2,
Well the maiden went great! I could shrink it to a 30" span. Shrinking the span won''t cut weight that much but it will increase the wing loading (stall faster). For a 30" wing it would probably make sense to cut it as 1 piece. I can do up to 48" on a single piece.
What size brushless are you looking at?
Chris
       Post #: 6
RE: Foam combat plane - 4/19/2008 12:48:56 AM
fly boy2
Status: online
Well first can I ask you is this? How well does it handle, like a noob or a novice can fly it, cause I'm still a bit in the beginner stage. and I really don't know what size of brushless motor or any kind of motor , I guess a motor that it pretty cheap. lol I might have a few R/C cars I can take it out of. lol
< Message edited by fly boy2 -- 4/19/2008 1:25:45 AM >
       Post #: 7
RE: Foam combat plane - 4/19/2008 12:41:15 PM
batchelc
Status: offline
Flyboy,
I wouldn't really know too much about converting a car electric motor to airplane R/C. I'm sure it can be done, but you would have to delvelop everything. The plane that I have designed uses a cheap 0.15 glow motor (60 bucks new, 30 buck os ebay). Electrics are going to cost many times more than that for a moror, batteries and speed control.
I flew the airplane again last night. I added some differential to the ailerons (one goes up more than the other goes down) and some additional vertical fin (rudder) area and I am much happier with the way it flies. It's very stable and could easily be flown by a noob.
I'm not sure that scaling it down would have the same flying qualities. Smaller airplanes tend to be twitchie.
Chris
       Post #: 8
RE: Foam combat plane - 4/20/2008 12:48:18 AM
fly boy2
Status: online
Its a 4 channel right. Can it go in inverted and do a snap roll? Do you have a video of the flight, if so can you sent it to me?
< Message edited by fly boy2 -- 4/20/2008 12:50:39 AM >
       Post #: 9
RE: Foam combat plane - 4/20/2008 4:41:41 AM
batchelc
Status: offline
Videos and pics at: http://www.wichitapilot.com/page.php?pageid=26
It's a 3 channel (ailerons, elevator, throttle) so no snap rolls. But it's easy to fly and lands slow. It can fly inverted and requires some elevator to stay inverted.
       Post #: 10
RE: Foam combat plane - 4/21/2008 3:18:42 PM
Montague
Status: offline
You don't need a rudder to snaproll, you just need enough elevator. A rearward CG helps as well. My SSC class planes will snaproll if I use ailerons and elevator, and yes, it's a real snaproll, not a barrel roll.
But if you're looking for nice acrobatics, you do need that rudder. Of course in combat we generally try to avoid snaprolls
Kirk Montague Adams
RCCA 560
       Post #: 11
RE: Foam combat plane - 4/23/2008 1:16:37 AM
fly boy2
Status: online
how much do you think you will sell it for? and it it assembled except for engine and radio when you sell them
       Post #: 12
RE: Foam combat plane - 4/23/2008 3:23:37 AM
batchelc
Status: offline
Flyboy I sent you a PM. Chris
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
