Big, Bad, Very Fast Bashing truck, which one...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> Big, Bad, Very Fast Bashing truck, which one...
Page: [1]
Login
Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 4:15:06 PM
fellers
Status: offline
Hey guys I am looking for a big very bad a$$ gas truck to beat on in the big rock quarries around my house. I have a revo and it is cool and all done up for bashing but I want a bigger faster truck. And cheaper to run than nitro.
I have some massive gasser planes and they are a blast. I am a firm believer in bigger is better
Don't really care about the price. I want Quality over anything. If I have to dump a ton of money in reinforcement parts it is not a good deal anymore anyways. I would rather dump my cash in performance parts; or a really sweet engine. I don't want to be fixing something every time I run the thing ya know...
With that in mind what should I get. I don't even know where to start
< Message edited by fellers -- 4/6/2008 4:16:02 PM >
_____________________________
" Wheres' The Beef ? "
       Post #: 1
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 4:20:44 PM
part-time
Status: offline
the fgs require several parts to make them hold up well about $200 worth. i have not really heard anything bad about the mcds but i dont own one. the mcds are also 4wd and have more ground clearance and bigger tires and a longer wheelbase.
(in reply to fellers)
       Post #: 2
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 5:16:53 PM
Snaut Rocket
Status: offline
Get a baja 5b ss if you already have a radio.
Why do they sterilize the needles for lethal injections?
Monster Gt 4.6: with brushless setup soon to come.
(in reply to part-time)
       Post #: 3
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 6:28:03 PM
Foxy
Status: offline
They're all good, and none is perfect out of the box. I have an HPI Baja, and an FG Monster Truck. The Baja was easy to get up and running out of the box, but has a cheaper engine, and crappy electronics (it was an RTR though, if you get an SS, you can put whatever electronics in you want). It's also a nightmare to work on and the diff needed filling straight away. The stock tires are pretty rubbish too, and the plastic beadlocks are a bit weak. Lastly the rear arm rub on the insode of the rims at full suspension travel, so you need a set of axle extenders. Also if you plan on big air, you'll need a fairly expensive shock shaft replacement. This is not optional, the stock shafts are VERY thin and weak.
The FG is usually bought as a roller with a Zenoah 26cc engine, which is a very nice powerplant. I'd say the FGs are slightly tougher out of the box, but they too have some weaknesses. The chassis flexes and messes up your gears. The upper rear arms hit stuff too when the chassis and suspension are flexing. The solution to this is alloy engine mounts, alloy spur and pinion carrier, and alloy upper rear arms. You will need a full set of electronics for the FG, unless you buy a shop's own 'rtr' package.
In both cases, you'll need at least $150 more for a good pipe to get the best out of the engines. It's hard to say which is better, they're both great fun in different ways. The baja is cool, but the FG has big wheels and pulls wheelies. I like them both equally. The FG took more money and effort to get 'right', but has a better engine and is a bit tougher, now that it's 'fixed'. I have ended up spending more on the Baja, simply because there is so much stuff available for it. If you like to hop stuff up, there's no contest, get a Baja, the aftermarket supply is superb, with loads of companies offering stuff you can bolt on. Don't know how much it will help, but here are some vids of my FG and the Baja...
FG - http://www.youtube.com/watch?v=MQHW2SPGb-U - This was when it was a Hummer, it's now a monster beetle.
Baja - http://www.youtube.com/watch?v=mcCA4WsRV7g - This car also looks very different now, and is undergoing a makeover.
Foxy. RCU Car Forums Moderator.
These opinions are my own and may not represent the views of RCUniverse.com
Check out my Large Scale Gas RC Car Vids... www.youtube.com/foxy4242
(in reply to Snaut Rocket)
       Post #: 4
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 7:15:55 PM
Snaut Rocket
Status: offline
Foxy is the SS kit Need all those replacements as the Rtr.
Or is the shocks tougher, and so it the tires?
(in reply to Foxy)
       Post #: 5
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 7:55:41 PM
snoking16
Status: offline
the shocks are tougher the dogbones are tougher...the tires are the same, the beedlocks are tougher, i think, the SS comes with a 26 cc engine and tuned pipe while the RTR is a 23cc and just a muffler.
My Beer Team has a Racing Problem
       Post #: 6
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 8:16:06 PM
beer=food
Status: offline
l want one of these next !
http://www.fgsupply.com/Marder_Models-BAJA_Desert_Racer_26ccm_transparent_body.html
Anyone got one, they any good ?
my revo is a bird, my baja a brick,
when l get em airbourne, its really quite sick,
all fun and games till they come back down,
and l land em like a frootloop backwards-arss clown !
(in reply to snoking16)
       Post #: 7
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 9:14:37 PM
Foxy
Status: offline
Snaut Rocket, to be honest, the SS is little better than the RTR, long term. The main things it has that are worth having are the alloy diff case, the swaybars, the engine, and the metal gear steering servo. Everything else needs upgrading just like the RTR. The shock shafts are just as bad, only the problem is different. When they thickened the shock shafts for the SS, they didn't change the plastic eye at the bottom where the shaft is connected to the lower arm, so where the shaft no longer bends, instead the plastic breaks. Basically, the SS offers some improved stuff, but nothing that you won't still upgrade anyway. Out of the 2 I'd say get the SS, but if you can't get one (stock issues), then the RTR is fine. I started mine as an RTR, never did any big air, and never had a single problem with it.
beer=food, that is the latest evolution of the marder based buggies from FG. It's a very good car, yes, and is supplied with a Zenoah 26cc engine. Better than that CY in your baja; stronger, faster, and longer lasting. There's a few owners on here, but really there's not a lot to say about it. It's FG quality, it's a RWD buggy, it's a good car. All the FG cars are the same chassis, the monsters have different gears, tires and rollcage, the Stadiums have, you guessed it, different gears, tires and rollcage, and the FG Baja? Yup, different gears tires and rollcage (and only 4 shocks and different arms).
(in reply to beer=food)
       Post #: 8
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 9:56:16 PM
bsrman14
Status: offline
Good luck finding anything with the guts to get the job done you want. The RTR (ready to replace) are low cost entry level machines. THe best is out of production. with the Rtrs you might as well buy all the upgrades and build it from scratch. Quality does come with a price. Too bad no one wants to pay for it now.
       Post #: 9
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 10:50:25 PM
Foxy
Status: offline
quote:
ORIGINAL: bsrman14
Can I ask you to qualify a few of those statements please, not cos I disagree necessarily, I just want to understand better what you mean? The HPI Baja RTR is a fine RTR, for eample, which are you referring to? Also, the best being out of production, may I ask which cars/manufacturers you are referring to? Also, people are spending ever increasing amounts of money, I don't understand what you mean when you say 'Too bad nobody wants to pay it now'. 5th scale is enjoying a huge boom at the moment...
(in reply to bsrman14)
       Post #: 10
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 11:51:44 PM
krayziedxc
Status: offline
quote:
ORIGINAL: beer=food
no idea. but im converting my monster beetle to a Fg baja desert racer. my parts are coming!! cant wait.
-FG BAJA
-KINGMOTOR BAJA
       Post #: 11
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/6/2008 11:55:45 PM
Snaut Rocket
Status: offline
quote:
ORIGINAL: Foxy
So foxy what upgrade is required for the shocks.
Is it a cheap one or am i looking to spending 100+ on them.
Becuase 900$ is a lot to spend on something thats just going to need repairs.
(in reply to Foxy)
       Post #: 12
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/7/2008 1:08:06 AM
Gas jocky
Status: offline
snaut rocket .. this is what you need
http://www.davesmotors.com/store/product2170.html
fellers... 2wd look at FG or HPI Baja5b, 4wd look at MCD or wait for FG's 4wd to come out (summertime?) lots of cheaper trucks avalible now aswell but sounds like you want quality over economy (Smartech, FS etc)
       Post #: 13
RE: Big, Bad, Very Fast Bashing truck, which one... - 4/7/2008 4:00:46 AM
fellers
Status: offline
Guys I do definately want quality. I don't know who said it above, "people aren't willing to pay for quality" because in my initial post i said price does not matter. If I have to get a rolling chasis that is fine. The motor absolutely has to a ripper and I am willing pay out the wazoo for a really really good BIG one.
I have the spektrum 3PR radio. Getting my own electronics is fine because you always get junk from manufacturers.
The hop up parts i don't want breaking always either ya know...
I like the baja but only being able to get a 26cc engine does not do it for me. Unless I am being ingnorant and a pipe and whatever else I can add will give it monstrous torque and blistering speed.
Ya think speed really gave a person a blister?
LOL kiddin. But I am learning and want to hear anything you guys have to say.
(in reply to Gas jocky)
       Post #: 14
