GST 7.7 problem high speed    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> CEN Racing >> GST 7.7 problem high speed
Page: [1]
Login
GST 7.7 problem high speed - 4/6/2008 7:51 PM
watapisr
Score: 100
Last Login: 5/24/2008
Status: offline
When i start the genesis 7.7 it will idle great runs good at 1/2 to 3/4 throttle but if i run at full throttle for more than 50 yards or so it dies, acts like it runs out of fuel and wont push fuel through the line even when i hold my finger over the exaust, if i let it sit for a few minutes it starts like a champ but still does the same thing over and over, Im new at this and dont have a clue, putting in new glow plug today to try that, any more suggestions?
Hide Signatures
       Post #: 1
RE: GST 7.7 problem high speed - 4/6/2008 7:59 PM
nomobux
Score: 105
Last Login: 4/25/2013
Status: offline
quote:
ORIGINAL: watapisr
Couple of things to ck. Sometimes they got some locktite in the exhaust pressure line fitting. Run a wire or something thru it to check. Check the O-ring on the tank cap and make sure you push the cap down tightly. Check that all fuel lines are tite and not against the head , etc. Have you messed with needle settings at all yet ? Is the truck new or what ? Also is this with a full or half tank ?
< Message edited by nomobux -- 4/6/2008 8:00 PM >
_____________________________
" I GOTTS NOMOBUX "
Hide Signatures
(in reply to watapisr)
       Post #: 2
RE: GST 7.7 problem high speed - 4/8/2008 9:08 PM
burningpoo
Score: 100
Last Login: 3/22/2009
Status: offline
Do you have a check valve installed yet? What glow plugs are you useing? Kind of sounds like your needles need to be setup
Taking unbroken toys aparts since 1981
Hide Signatures
(in reply to nomobux)
       Post #: 3
RE: GST 7.7 problem high speed - 4/9/2008 4:25 AM
chrobar
Score: 100
Last Login: 4/16/2012
Status: offline
Sometimes when you are at about 1/2 tank, you can experience 1/2 tank lean. This means that the fuel to air mixture gets leaner than usual, and could be setting off your settings. Try to richen the mixture a bit and see how it goes. Make sure to try and check your temperature with either a temp gun, or using the spit test. If the temp is over 260 or so, it could be that the mixture is too lean.
*Team Terribles* CEN Matrix C-1 FRE, Sportwerks V2 .21, JP3 pipe, Futaba FASST...Soon to be R2 FRE
Hide Signatures
(in reply to burningpoo)
       Post #: 4
RE: GST 7.7 problem high speed - 4/9/2008 5:50 AM
watapisr
Score: 100
Status: offline
Thanks to all for the help, I will check all. I did find that i wasnt getting a good seal from the exaust header to the pipe think that might have solved my problem. After i figured that out i lost a dang wheel and threw the pin that holds the wheel on.......I know I know....... anyway ordered parts from cen should get them later in the week ill let you know how it goes.
Hide Signatures
(in reply to chrobar)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
