Small 18V pack??
Tower Hobbies
Logged in as Guest
  Printable Version
FISHER FUEL PRODUCTS 5 GALLON & 2.5 GAS FUELERS
Seller:  hunternfla
Details:   $220.00   |  6/24/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Small 18V pack??
Page: [1]
Login
Small 18V pack?? - 4/6/2008 4:57:26 PM
joshco84
Status: offline
Ok guys, i used to be into r/c cars and i know a lot of people built there own packs. I figured you guys would be the best to ask this question to. I need to build an 18V pack either the same size or smaller than 2 9V batteries. Is this even possible? It is going in an electronic hopper for a paintball gun, and i want something better than regular nine volts. Is there a way to even build a pack that small with that much voltage? Thanks in advance for the help guys.
       Post #: 1
RE: Small 18V pack?? - 4/6/2008 5:05:25 PM
guver
Status: offline
If you need it to be smaller than 2 9 volts, then going to a lipo battery would be best bet. For the same size battery you can get a much higher voltage. It should be able to have similar capacity and voltage and be about the size of 1 9 volt battery. I sure don't know where to get the cells though.
Check this site perhaps sorting by size. http://www.progressiverc.com/Research.html Use a 4s or 5s depending upon what actual voltage you need.
_____________________________
This is an apostrophe ''
(in reply to joshco84)
       Post #: 2
RE: Small 18V pack?? - 4/6/2008 5:16:54 PM
joshco84
Status: offline
Ok, thanks for the help, I really appreciate it. The only problem is i have no idea what all those numbers mean. Is there an faq for that stuff somewhere?? Also i didnt find it showing voltage on that chart. Am i just looking wrong?
(in reply to guver)
       Post #: 3
RE: Small 18V pack?? - 4/6/2008 5:53:26 PM
guver
Status: offline
The voltage may not be on there. For lipos a nominal voltage of 3.7 per cell is used , and that will correspond with an empty pack. 4.2 volts per cell is for a full pack. Depending upon how hard the current draw is the operating voltage may be anywhere between 3 and 4 volts per cell. Usually it works out to divide the number of nimh cells by 3 to get the lipo equivellant.
4S column should be 14.8 volts
5S column should be 18.5 volts
You may even want to go with 6S for higher voltage.
       Post #: 4
RE: Small 18V pack?? - 4/6/2008 5:55:19 PM
guver
Status: offline
The smallest pack I see is a 500 mah and is probably still way too big , I don't get into tiny batts really , but if you search for a truck called the mini-t it may use some very tiny cells. Maybe they would be small enough.
(in reply to guver)
       Post #: 5
RE: Small 18V pack?? - 4/7/2008 1:51:03 AM
joshco84
Status: offline
Ok, thanks for the help guys. I think i may just make a pack with two nine volts and put a single connector on it. I would then change the dual connector in the loader to a single as well. Thanks, and ill be back, im sure ill have more questions. Thanks Again
Josh
(in reply to guver)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
