hover issues
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> RC Helicopter Heaven Support >> hover issues
Page: [1]
Login
hover issues - 4/6/2008 5:57 PM
jibaless
Score: 100
Last Login: 4/26/2008
Status: offline
Im new to the craft and it seems that even at full throttle my honey bee cp2 will not lift fully, but will only get light on the skids. Anyone know a way to fix this, ive been told it was the angle of the pitch, and it seems i have no clue how to get this fixed, anyone able to help me here?
Hide Signatures
       Post #: 1
RE: hover issues - 6/8/2008 6:19 AM
Heli Head
Score: 100
Last Login: 11/15/2008
Status: offline
Do you have a pitch gauge to check what pitch your main rotors are at, at half stick? You should be in the +4-5 degree pitch range at half stick to get the heli light on the skids. If memory serves me - the Honey Bee CP and CP2 don't have adjustable throttle/pitch curves with the basic radio they come with. If that is the case, you will have to adjust your pitch manually by adjusting the push rod lengths. Don't know enough about the HB CP to give you the exact procedure.
Does the motor seem to be at full speed? The other possibility is that you are not getting enough power from the motor - just a thought.
Cheers,
John
www.rchelicopterfun.com
Hide Signatures
(in reply to jibaless)
       Post #: 2
RE: hover issues - 6/10/2008 6:49 AM
jimmy 1987
Score: 100
Last Login: 4/28/2009
Status: offline
Disconnect ur motor then turn the transmitter on and plug the battery in.
Wait for the tail servo to initialise then put the throttle at half way,
now the blades need to be at 0 pitch (flat) use a pitch guage to get it close as possible,
put the throttle back down, unplug the battery
plug the motor back in then the battery again and now you have to get the blade tracking right then your should be right.
use the adjustable knobs on the tranmitter to give it a little more pitch, i put it at about 3 o clock on both of them to give it a lilttle more pitch so the battery last longer.
hope this helps
Hide Signatures
(in reply to Heli Head)
       Post #: 3
RE: hover issues - 10/31/2008 9:26 PM
helicrazedout
Score: 100
Last Login: 11/7/2009
Status: offline
have you checked your battery is ok use a volt meter also check that your charger is functioning ok you might not be getting a full charge.
_____________________________
450 size- Dx7 AR7000 JRg490t gyro Hyperion titan 30a esc Towerpro sg90 servos Hitec 81hs tail servo esky motor
Hide Signatures
(in reply to jimmy 1987)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.221RCU1
