LunaSea
FL, USA Status: offline
Ron, Looks like you are doing a great job. I live in Jacksonville, too. I know you from a company I used to own, TSPI. I have also seen you at the flying field a couple times. I noticed your note about covering from Tower. Certainly nothing wrong w/ that, but I have found that I REALLY like the uncertified aircraft dacron from Aircraft Spruce and Specialty. It is a LOT less expensive than anything we buy for models, is very lightweight and strong, shrinks very nicely. It does require an adhesive. I have been using Balsarite and it works well. Fill it with either water-based polyurethane or polycryllic and paint with Rustoleum spray cans. Easy to get a very nice finish that is VERY strong. Also, I saw that you are planning on an ST3000 for the plane. Have you considered a small gasser such as a G-26 or maybe a weedeater conversion? That would work very well is this plane, give very scale flight acteristics and a LOT cheaper to fly (almost NO gooey stuff on the plane either...)... Best wishes, I look forward to watching this thread as you finish the plane. I hope to see it in person at the field... Ernie
