Optic 6 Truth ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Optic 6 Truth ? Page: [1]
Login
Optic 6 Truth ? - 4/8/2008 10:52:59 PM
hans
Status: offline
Any truth to the rumer, the Optic 6 Loses saved models programing if the battery is unpluged?
       Post #: 1
RE: Optic 6 Truth ? - 4/8/2008 11:34:16 PM
A.T.
Status: offline
quote:
ORIGINAL: hans Any truth to the rumer, the Optic 6 Loses saved models programing if the battery is unpluged?
Negative.
The Optic 6 can retain 8 models into the internal memory. This memory is non-volatile memory and requires no back-up battery or other power source to retain any of the model settings. You may remove the main battery pack without worry of memory loss within the transmitter. Each model memory position is separate and distinct from all others, meaning that whatever settings you create or delete on one model will have no bearing upon any other model memory setting. The factory default for any model position in memory is the Acro/Glider (ACGL) type.
Eclipse/Optic FAQ may also assist.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(in reply to hans)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.203RCU1
