nikg
patternwanabee---I think your statement about generating less current as voltage rises is dead on. I have checked the current from the wal warts at several points during a charge and have noticed the difference. For instance, my 350mA wart measured 420mA near the beginning of a long charge cycle, but closer to the end it measured 350mA which is what is was rated at for 9v. I think this may be due to one of two things, or maybe both (or neither---someone please correct me if I'm wrong) 1--The power output "wants" to remain constant, so at lower voltage the current must be higher in order to produce the same power as a higher voltage with lower current. This would explain getting closer to the rated current as the voltage neared 9v(rated voltage). 2--I'm less sure of this one, but as a pack gets charged I think the resistance builds. At first, the cells accept current with little resistance because they are "empty", but as they fill they become more resistant. This in turn lowers the amount of current that can flow from the power source. I like to think of it like blowing up a tire with one of those wimpy little bike tire compressors (that I have and love even though it takes forever) With a flat tire you can hear the pump screaming away as it fills the low pressure space, but as the tire builds PSI you can hear the compressor start to struggle. To me this seems analogous to the battery charging situation. Again, please correct me if I'm wrong, or affirm that I am on to something. As far as getting a wart that produces an appropriate charge rate, just get one that is C/10 for the lowest mAh pack you want to use it with. You can always charge that pack for 12 hours and charge the higher capacity packs for longer. At such a low current it should not damage anything if you accidentally leave them overcharging for a short period of time (a few hours)
