plastic welding
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> plastic welding Page: [1]
Login
plastic welding - 4/9/2008 6:45:16 AM
fozjared
Status: offline
tonight i started on a spad project i have been wanting to get going for quite some time.. i went to spadtothebone.com to do a crash course as this is my first spad to build (i have one now that i had given to me) most of the recommendations on the planes were saying to use medium ca, so i did.. it was working pretty well and all, up until i folded the top portion of the wing to the bottom portion, the pull of the coroplast kept pulling the glue apart in places, so i used a trick that i have used before on the plastic on my dirt bike.. i used a pencil size/shape butane torch (doesn't have to be pencil shaped obviously, just easier to handle than the cylinder) you can buy these pencil torches at attwoods or tractor supply co. for around 2 bucks, well worth it!! back to the story, i took the torch and my xacto knife and heated the plastic to melting point (kinda ugly, made burn holes in places) and then mixed the plastic of the wing pieces together and it was like one solid piece of plastic, just like on my dirt bike!!
for those of you who fly spads, well for anyone really.. this is a big gasser (39cc) spad so i made the wing 84" x 16.5" x 2" and i made the horizontal stabilizer 11" x 32" (including elevator) no airfoil, and the rudder/vertical stab 12" x 4"at top and 8" at bottom (tapered on the leading edge) and the fuselage 64"
so 84" ws 64" fuse and 11x32 horz. stab. will that fly well with a 39cc engine (magneta ignition left on)?
my main question actually is how on earth am i gonna be able to keep the tail feathers from shaking to pieces from flutter? how can i stabilize the stabilizers?
thanks for the help and i hope that the info on plastic "welding" can be used by some, it turned out extremely strong for me!
       Post #: 1
RE: plastic welding - 4/9/2008 12:25:23 PM
mclina
Status: offline
For any wide, flat surface of coroplast, the best way to stiffen them is to get the biggest diameter music wire which will fit inside the flute, and jam it all the way through. On a big surface, you may want to put in a couple of them. I believe the size is 5/32" music wire. This is what is used for wing spars on some planes, like the SPA3DT and the Gnat.
Good luck. I can't wait to see the finished product.
< Message edited by mclina -- 4/9/2008 12:26:41 PM >
_____________________________
If all of your friends were named Cliff, would you jump off them? - Hugh Neutron
(in reply to fozjared)
       Post #: 2
RE: plastic welding - 4/9/2008 3:52:42 PM
Villa
Status: offline
I would make the vertical and horizontal stabs two thicknesses of 4MM coro. You may still have to brace them with flying wires.
(in reply to mclina)
       Post #: 3
RE: plastic welding - 4/9/2008 7:16:12 PM
fozjared
Status: offline
i think i am going to double the tail feathers and wire them as well as run music wire through the flutes, thanks for the advice.
(in reply to Villa)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU1
