Connect two LiPo Battery (7.4v and 11.1v)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Connect two LiPo Battery (7.4v and 11.1v)
Page: [1]
Login
Connect two LiPo Battery (7.4v and 11.1v) - 4/9/2008 4:27:54 PM
neuroza
Status: offline
Hi!
I have one simple question.
Is it possible (and safe) to connect two LiPo battery:
-one battery is 2 cells, 7,4v, 2250 mAh
-the second is 3 cells, 11,1v, 3900 mAh
How to connect it, the classic way: first battery +(red) connect to second battery -(black) wire???
Is that correct or is there some other metod???
Any suggestion will be appreciated.
Thanks!
       Post #: 1
RE: Connect two LiPo Battery (7.4v and 11.1v) - 4/9/2008 6:13:26 PM
guver
Status: offline
It would not be good to connect in parallel because the high voltage one would overdischarge while it overcharged the lower voltage pack.
Even the series connection would be a bad idea because when used the smaller pack would get used up first causeing it to run low on voltage and damage resulting.
_____________________________
This is an apostrophe ''
(in reply to neuroza)
       Post #: 2
RE: Connect two LiPo Battery (7.4v and 11.1v) - 4/9/2008 6:37:48 PM
Arceenut
Status: offline
It would be OK to connect the two only in SERIES as long as the two packs had the same Mah capacity and discharge rating. Connecting them in PARALLEL will destroy them as the higher voltage one would overcharge the lower voltage pack and the higher voltage pack would over discharge.
       Post #: 3
RE: Connect two LiPo Battery (7.4v and 11.1v) - 4/9/2008 11:18:27 PM
neuroza
Status: offline
OK, so what is a PARALLEL and what is SERIES connection???
and ih I have two battery with the same mAh, can I connect it??
(in reply to Arceenut)
       Post #: 4
RE: Connect two LiPo Battery (7.4v and 11.1v) - 4/10/2008 1:01:59 AM
Flying Geezer
Status: offline
If you don't know the difference between parallel and series, don't try it. Get some help.
Flying Geezer
Hughes RC
       Post #: 5
RE: Connect two LiPo Battery (7.4v and 11.1v) - 4/10/2008 9:13:08 AM
guver
Status: offline
I agree with geez, get some help.
If the packs are the same voltage (actual voltage) they can be hooked/used/charged in parallel.
If the packs are the same capacity then they can be hooked/used/charged in series. They should be exact same capacity and level of charge.
This helps with connections. http://www.commonsenserc.com/page.php?page=lipo_wiring.html
(in reply to Flying Geezer)
       Post #: 6
RE: Connect two LiPo Battery (7.4v and 11.1v) - 4/10/2008 12:37:17 PM
neuroza
Status: offline
Thanks for helping!
OK, so, how to connect two identical battery (11,1v 3900mAh, 3 cells in one battery)
(in reply to guver)
       Post #: 7
RE: Connect two LiPo Battery (7.4v and 11.1v) - 4/10/2008 6:02:02 PM
83gt
Status: offline
Connecting packs in parallel combines the capacity of both packs. So if you have two packs that are both 3s 3000mAh and you connect them in parallel, you have a 3s2p 6000 mAh pack. This is done by simply connecting the positive on both packs together, and the negative from both packs together.
Connecting in series you would connect the positive of one pack to the negative of the other pack. This would give you the capacity of a single pack, but double the voltage.
Unless we know what you are looking for, it's hard to give you some advice. Are you trying to increase runtime, or increase voltage for more power ?
J.
E-Savage | Tamiya CC-01 | Tamiya DI | Tamiya Stadium Raider | Losi MLST | AE RC10T3
       Post #: 8
RE: Connect two LiPo Battery (7.4v and 11.1v) - 4/11/2008 5:54:27 PM
neuroza
Status: offline
Ok, this is everything I need to know, thanks again!
(in reply to 83gt)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.500RCU1
