Trouble locking signal between Evo 12 xmitter and Fusion 9 rcvr
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Trouble locking signal between Evo 12 xmitter and Fusion 9 rcvr
Page: [1]
Login
Trouble locking signal between Evo 12 xmitter and Fusio... - 4/10/2008 12:23:08 PM
MTR69
Status: offline
I have two Fusion 9 rcvrs and two Evo 12 xmitters. I hook up either rcvr with a 2 cell A123 battery (no regulator) and a single MPX servo, go through the syncing procedure using either transmitter, then turn the rcvr off & back on (xmitter already on) and the rcvr does not lock onto the xmitter's signal. When I turn the xmitter off & on, the rcvr usually locks on. Once it locks on it is rock solid.
Just to clarify - rcvr on first, then xmitter on and it locks on (not every time though). Xmitter on first, then rcvr and it will not lock on.
This is consistently true using either xmitter with either rcvr. I resynced every time I switched either the xmitter or rcvr. I maintained about 6 ft separation between xmitter & rcvr during testing. I know no other xmitters in my house are switched on but I have no way to check if there is some sort of other interference
Now, the interesting part - The Evo 12 xmitters work fine with my MPX 12ch rcvr. It appears that the problem lies with the Fusion rcvr.
What to do???
       Post #: 1
RE: Trouble locking signal between Evo 12 xmitter and ... - 4/11/2008 8:39:19 PM
MikeMayberry
Status: online
I've not heard of this issue before but my suggestion would be to just use the procedure that works! It's kind of like when you tell the doctor "Doc, it hurts when I do this..." and the doctor says... well don't do that then!!!
If you think it's a problem then send them in and we can check them out.
Mike.
_____________________________
Hitec RCD Rep
http://www.hitecrcd.com
(in reply to MTR69)
       Post #: 2
RE: Trouble locking signal between Evo 12 xmitter and ... - 4/11/2008 11:11:41 PM
MTR69
Status: offline
Mike,
OK, thanks.
(in reply to MikeMayberry)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.266RCU1
