64a vibration
Tower Hobbies
Logged in as Guest
  Printable Version
O.S. Engines O.S. BGX-1 3500 w/ BCM #4224 Pitt
Seller:  jmhernan
Details:   $200.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Fuji-Imvac Engines Support >> 64a vibration
Page: [1]
Login
64a vibration - 4/11/2008 3:12:04 AM
whatwind
Status: offline
just got around to installing the 64a I got at the begining of this year the first time I started it it had a lot of vibration at mid range. I will admit that the first batch of fuel i mixed up I didn' t check my can very good and had some gunk in it that got into the carb before I could shut it down. I had primed the carb and it fired right up and sucked the stuff into the carb. I cleaned out the carb and re worked the fuel system. got the fuel system working right started it agan the vibration at mid range more like it was trying to jump off the table I brought it back to idle I let it run for a few a while because bolts and nuts were coming off the plane. The prop a 20/10 master airscrew clasic was and is balanced I noticed a scuff mark on the magnito put a gage to it on the prop flang 3 onethousand out at the scuff Is the master airscrew to heavy for the engine? the engine starts easy idles low throtle is great but do I need to send it in for a bent crank?
       Post #: 1
RE: 64a vibration - 4/14/2008 3:34:23 PM
Bax
Status: offline
You''ll have to check the engine carefully to see if there''s something bent. If something was bent, though, you''d see high vibration levels at all RPM settings. Operation in the midrange can produce rougher running on some engines. It depends upon the propeller and the mixture setting. It may also be that the structure of the model really isn''t up to a large gasoline engine. This is more common that some may think...especially if the airplane''s being overpowered.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to whatwind)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
