Airbike
CA, USA Status: offline
I'm not sure of the torque on the HS82 but I am using HS-85MG's in one of my LR-1's. So far no problems and it is running a Sport Jett .50 You might get away with the HS82MG if powered with a .25 but with a .32 or larger, I'd think you'd want a little more servo power. I'd recommend cutting one side of the skin and making the rudder operable, it needs all the ground control you can get. There was a nice thread on the LR-1 a few years ago, maybe a search will turn it up.
_____________________________
The more you put into living, the more you get out of life. Revver #150
