Power Expander Sport Question
Tower Hobbies
Logged in as Guest
  Printable Version
Top Flite GS Stab Relocation Kit - Kit
Seller:  tony-howard
Details:   $12.50   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Smart-Fly (Quest Engineering) Support Forum >> Power Expander Sport Question
Page: [1]
Login
Power Expander Sport Question - 4/11/2008 5:39:25 AM
wttiger42
Status: offline
I just purchased the Smart Fly PE Sport.
I installed it in the plane tonight and soldered deans plugs onto my fromeco regs and hooked them to the PE plugs (yes + and - are correct)
I get no power to the servos. The lights on the board are on. Im using a JR 649 Receiver
Am i correct in this: I do NOT plug anything into the battery port on the JR receiver?
I just plug the power leads on the left side into the throttle port, then the other power leads into the last aux?
       Post #: 1
RE: Power Expander Sport Question - 4/11/2008 5:56:07 AM
masonman
Status: offline
Do the wires on the expander that plug to the rx have only one wire in the plug not three? If it only has one wire the signal wire then. then no your rx has no power.
Would need to see a picture or something. Just speculating is all i can do without seeing anything
(in reply to wttiger42)
       Post #: 2
RE: Power Expander Sport Question - 4/11/2008 6:18:44 AM
wttiger42
Status: offline
Ill get a pic tomorrow. On each end, the lead has three wires. The center ones only have the signal wire.
(in reply to masonman)
       Post #: 3
RE: Power Expander Sport Question - 4/11/2008 2:08:54 PM
tail strike
Status: online
Here is a picgture of my setup, as you can see there are three wires on the end leads, that is how yours should be.
Click to see fullsize image.
Click for fullsize
_____________________________
I am watching you
Larry S
       Post #: 4
RE: Power Expander Sport Question - 4/11/2008 3:15:58 PM
wttiger42
Status: offline
quote:
ORIGINAL: tail strike
Thanks for the pic. Is your battery leads from the PE plugged into the throttle port and the next port? It looks like maybe your throttle port and the next port are what your PE power leads connect to.
(in reply to tail strike)
       Post #: 5
RE: Power Expander Sport Question - 4/11/2008 3:25:41 PM
rrritchey
Status: offline
Hi wttiger42,
If both LEDs on the board are on you are getting power to the servos. The 3-lead connector off the Sport to the receiver should go in Thro and the last Aux on a JR receiver. Are you sure you have the servo plug in the correct orientation? The orange wire should be to the inside of the unit near the notch in the servo lead guide.
Robert Ritchey
Owner, Smart-Fly
       Post #: 6
RE: Power Expander Sport Question - 4/11/2008 3:37:23 PM
wttiger42
Status: offline
quote:
ORIGINAL: rrritchey
Hi wttiger42,
I confirmed the wire orientation was correct by bypassing the PE and plugging the regulator directly into the receiver along with the servo extension. I havent hooked the 3-lead wire into the throttle port. The servo wires on the PE itself are wired with the signal wire on the side with the 'top hat' symbol.
I currently have it hooked up like this (which doesnt work): 3-lead into the battery port on receiver, 3-lead into the Aux 4 port and the rest of the 1-leads into the receiver parallel.
Could this be the problem? It wont work because of the battery port and maybe my Aux 4 is inhibited? Or does that not matter with power?
(in reply to rrritchey)
       Post #: 7
RE: Power Expander Sport Question - 4/11/2008 3:43:35 PM
rrritchey
Status: offline
Hi,
Putting the 3-wire into the battery port on the receive puts the receiver into DSC mode where it stops listening to its antenna (the transmitter). You have to hook it up the way we say, first 3-lead into throttle, then plug all the single wires in and lastly plug the last 3-lead into any aux port left open.
Robert Ritchey
Owner, Smart-Fly
       Post #: 8
RE: Power Expander Sport Question - 4/11/2008 3:51:11 PM
wttiger42
Status: offline
quote:
Hi,
Well, that solves the problem! All the ways i tried to fix if have had the 3-lead plugged into the battery slot. If that is true about the DCS mode, then that should solve it.
Thanks again for your help!
       Post #: 9
RE: Power Expander Sport Question - 4/11/2008 5:25:57 PM
tail strike
Status: online
quote:
ORIGINAL: wttiger42
YEs you are right there is a buss in the reciever you could actually plug a battery into any open port.
But I have since moved the battery plug to the bottom of the reciever where you would plug in the binding plug.
Hope I am not confusing you
I am watching you
Larry S
       Post #: 10
RE: Power Expander Sport Question - 4/11/2008 5:29:33 PM
rrritchey
Status: offline
Hi TailStrike,
You do NOT want to do what you did. You may unbind your receiver, at a very inconvenient time. You should not plug any connections from the PowerExpander to any port on the receiver but servo ports. Bind ports and data ports are NOT ACCEPTABLE to plug any of the PowerExpander plugs into.
Robert Ritchey
Owner, Smart-Fly
       Post #: 11
RE: Power Expander Sport Question - 4/11/2008 6:04:07 PM
tail strike
Status: online
Hmmmmmmm I didn't know that, I guess I should put it back to the battery port like it is in the picture
I am watching you
Larry S
       Post #: 12
RE: Power Expander Sport Question - 4/11/2008 6:27:46 PM
tail strike
Status: online
Robert
on looking at my JR921 recieve There are two ports on the pottom of the reciever
Looking at the picture of the reciever the port on the bottom is labeled BAT1/BIND and the other bottom port is labled BAT2/DATA
That is why I did it that way.
Do you still say I shouldn't do it that way?
Thank you
Click for fullsize
I am watching you
Larry S
       Post #: 13
RE: Power Expander Sport Question - 4/11/2008 6:52:29 PM
rrritchey
Status: offline
Hi Larry,
You should not be plugging any of the connections from the PowerExpander into the BAT/BIND or BAT/DATA. Its probably not a problem on the BAT/DATA but with any connectors in the BAT/BIND it might go into bind mode at any time. This is why we say in the instructions not to plug into the battery port on any receiver.
Robert Ritchey
Owner, Smart-Fly
