Remby
PA, USA Status: offline
Update on the Duck's flight attempt.. I balanced it at a forward point, close to the full forward position given on the computer. Started the engine, and let her go. Once in the air, it acts like a Pelican and heads for the fish in the water. So, first flight, and we have roast duck. Damage not too bad, and this was fixed. Next day, another go. The balance was shifted to the rear, the minimum given on the numbers. This time, the arc is larger, but still hungry for fish. The Duck bent it's beak. Will take a bit to fix it, should still fly. Based on what is going on , it is the down thrust from the engine that is not correct. When this was downsized,I had to push the engine higher on the rudder so the prop would clear. Thus, the engine is higher ,and causing the loop effect. I need to add more downthrust, right now it is -2 degs, and am not sure how to figure a correct thrust line. Any input from you'ins would be great, let me know what you think may help get it right. And I can go with a 5*3 prop, and lower the mount if the downthrust deg idea flys south.
_____________________________
1/2a flyer !
