Yuu
Joined: 9/4/2006 From: Shawano, WI, USA Status: offline
Remby... I didn't mean to give you a 'yuck'. Just now I went back to the first post, again, and from what I see in the enlarged picture, the 'orange' color of the front wing looks like the elevator, and the 'red' is the canard solid portion attached to the fuse. So the elevator [moving] portion looks like maybe 1/2" by 20" [less the width of the fuse]. My RC canard front wing is 12" by 4" total, and covers a 2" wide fuse. The stationary area is 12" by 2" with 2" by 2" glued to the fuse, and a piece 2" by 2" between the elevators glued to the fuse. That leaves Two elevators each 5" by 2", one each side of the fuse, both of which move up and down 35 degrees. So my canard plane has 10 + 10 = 20 square inches of moving elevator. If your fuse is 2" wide, then your elevator area is 9" by 1/2" plus 9" by 1/2", or about 9 square inches total. That's less than half the area of the elevator on my plane, built as per the kit. Perhaps I'm looking at your picture incorrectly, as I can not see a 'hinge line' on the canard. My previous post was an intent to say, "Looks like you need more control surface in the front." One of your posts did say that the plane dropped its nose and went down...... perhaps more "UP' elevator surface could correct that.
