Futaba FASST Product Advisory - R6014FS Receiver
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Futaba Radios Direct support forum >> Futaba FASST Product Advisory - R6014FS Receiver
Page: [1]
Login
Futaba FASST Product Advisory - R6014FS Receiver - 4/11/2008 3:25 PM
Bax
Score: 100
Last Login: 7/2/2009
Status: offline
Futaba Product Advisory- R6014FS Receiver
Whereas many previous receivers offered a signal output of 3.0 Volts, the latest generation of IC’s has been designed to operate at lower voltages in order to increase their operational speeds. The R6014FS receiver utilizes such an IC and, as such, the nominal output voltage of the R6014FS receiver is 2.7 Volts.
While this variance in the output voltage will not affect most equipment in use today, it has been brought to our attention that some manufacturer’s products are not capable of operation with the lower voltage. That is, they will not operate below 3.0 volts. Some examples of what we have had reported thus far includes sequencers, cut-off valves, older servo designs and some recent non-Futaba digital servos.
Some battery back-up devices might have difficulties with the lower operational voltages as well, although they might not appear to initially. One such device functions perfectly on the ground and during a range check, yet when the operational temperature reaches 50 degrees C (122 degrees F), the device actually requires 2.8 Volts in order to function properly. As such, the servos will cease to operate properly.
Many of the manufacturers are updating or refining their products to ensure compatibility with the lower operational voltages. Should you have any questions about the operation of such peripheral items we strongly suggest that you contact the manufacturer directly.
If you have already purchased items which are not capable of operation below 3.0 Volts, we suggest that you replace the item with an updated version.
< Message edited by Bax -- 8/19/2008 5:09 PM >
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
       Post #: 1
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
