Metalmorphous
CT, USA Status: offline
Thanks Guys I think this is going to be fun project. Tom I will check that out, just what I need,,, another project I forgot to explane the pictures 1. This is a picture of the fullscale turbo 2. This is the vacuforum that comes with the Z kit 3. There is a little more detail inside the form 4. After waxing, I applied a thin layer of fiberglass and cloth 5. After curing, I removed the new turbo from the mold and it can be reused 6. I bonded the two parts together and made the recess for the turbo, the original location was too high 7. A little primmer and a rough fit, I will go over the vent and installation 8. A little more detail added 9. The turbo is metal plated --- I did have some some warpage bue to a high temp setting on the plating equipment, but a heat gun was a quick fix The part is brushed with water and a low temp on the heat gun make good rust 10. I let the part air dry, and now the turbos look like they have been out side for years, 11. Another fit with the turbo recessed plated in a metal that looks like stainless steel and the rusted turbo has been airbrushed along with the area behind the exhuast port, this is just a test, I will remove the paint before the part gets plated in aluminum. 11. A close up of the details added
< Message edited by Metalmorphous -- 4/13/2008 4:58:58 PM >
_____________________________
www.metal-morphous.com
