UfcGuy39
Joined: 2/7/2008 From: Waukegan, IL, USA Status: offline
As for the trex se V2 tail shaft working, no it really doesn't. It has some extending plastic on the tail side, which makes it a tad too wide to fit right inside of the tailcase. It fits, but the screws shut about 1 to 2 mm short of closing on the shaft. I suppose if you were to dremel off the extending plastic, (which acts like a bearing), you can use the 2 metal bearing pieces from the stock in its place. I just figured why bother. Replaced the entire tailcase. I am going to get rid of the stock tailcase this weekend, for the HDX V2 - from with what I've been hearing, it is much better that the Trex and Stock Art-tech. I have found that the stock pitch sliders like to bind, unless I keep it greased up well. PeAce. Ufc...
_____________________________
Rc Heli''''s "Not just a hobby, also an addiction".
