Physics and equations of top speed+torque!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> Physics and equations of top speed+torque!!!
Page: [1] 2   next >   >>
Login
Physics and equations of top speed+torque!!! - 4/14/2008 10:02:28 AM
GYNAIKAS
Status: offline
I did the project as Impulce requested. Since RCU was under maintainace I did it on paper...and you know I''m lazy (I don''t have a scanner too) so here you go! Pm me for any questions.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
I simply love perfection...do something as good as you can or don't do it at all...
       Post #: 1
RE: Physics and equations of top speed+torque!!! - 4/14/2008 2:34:46 PM
ziggy12345
Status: offline
What on earth is all that hieroglyphics??
Put the lot into a spreadsheet so the user can adjust the inputs and see th results.
Cheers
(in reply to GYNAIKAS)
       Post #: 2
RE: Physics and equations of top speed+torque!!! - 4/14/2008 2:51:43 PM
GYNAIKAS
Status: offline
Honestly it''s the simplest it can be...I explaining everything step by step and in the end there''s the final formula for calculations. I also write what every single variable represents. Give it a try and you''ll understand for sure.
(in reply to ziggy12345)
       Post #: 3
RE: Physics and equations of top speed+torque!!! - 4/14/2008 7:13:53 PM
Cypriot Boy
Status: offline
WOW that a lot of math and calculations!!! just trying to undersand!!!
I am glade that i am able to say that i have a prototype/concept car.... Team Magic G4+....
       Post #: 4
RE: Physics and equations of top speed+torque!!! - 4/14/2008 7:22:12 PM
773W
Status: offline
Here''s one of the calcs i did up a while ago. (R/C)= fun/smiles!!
Racing is a sport......Building and fixxing are hobbys......(Just a thought)
(in reply to Cypriot Boy)
       Post #: 5
RE: Physics and equations of top speed+torque!!! - 4/14/2008 7:29:57 PM
dsales
Status: offline
Can you put all this quantum mechanics into simple English please
       Post #: 6
RE: Physics and equations of top speed+torque!!! - 4/14/2008 7:41:33 PM
GYNAIKAS
Status: offline
Quantum mechanics? Well they were teaching us these things at high schooll and i can show you a 3rd grade book if you don''t believe me (it must be somewhere in a bookshelf...it''s been 6years till I last saw it, LOL)! Honestly there''s nothing hard if you spend some time reading it all. If you trust me rely on the final equations. All the other stuff is simply the mathematical documentation of the final equations on each page.
(in reply to dsales)
       Post #: 7
RE: Physics and equations of top speed+torque!!! - 4/14/2008 8:02:12 PM
GYNAIKAS
Status: offline
Let me give you a brief example. My engine revs at 38000rpm max. So (rpm)e = 38000 r/min (hpiracing sais 40000 out of the nitro star 18ss but I don''t believe them.LRP z.18 makes 36000 but mine is modified so I''m almost sure that it revs somewhere around 38000 practical). I use 23T pinion (2nd gear) and 43T spur. So T1=23 and T2=43. Also the final gears are Tf1=13 and Tf2=38. Also the wheel radius of my current wheels (rim+tire) is 3.4cm. So Rw=3.4
Vmax = 0.003768*((T1*Tf1*Rw)/(T2*Tf2))*(rpm)e => Vmax=0.003768*((23*13*3.4)/(43*38))*38000 => Vmax = 89.0825 [Km/h]
To convert that in mph: Vmax[mph] = 0.62*Vmax[km/h] => Vmax[mph] = 0.62*89.0825[km/h] => Vmax[mph] = 55.23mph
       Post #: 8
RE: Physics and equations of top speed+torque!!! - 4/14/2008 8:12:21 PM
dsales
Status: offline
Ok, I finally get it
       Post #: 9
RE: Physics and equations of top speed+torque!!! - 4/14/2008 8:18:46 PM
GYNAIKAS
Status: offline
Another example: Fot the same car (same max rpm, same final gear ratio) What gearing do I need to get to 70mph if I''ve already found bigger foamies (larger radius->more top speed), let''s say with 4cm radius (the ones that miami guys use)??? (searching for the T1/T2 ratio)
Solution:
We have to calculate backwards. With easy modifications I rebuild the equation: Vmax[mph]=0.62*Vmax[km/h] => Vmax[km/h] = 70mph/0.62 = 112.9km/h
(T1/T2) = (Vmax*Tf2)/(0.003768*(rpm)e*Tf1*Rw) => (T1/T2) = (112.9*38)/(0.003768*38000*13*4) => (T1/T2) = 0.57621
So for the current T1 pinion gear (23T) I need T2=39.916T wich means that using the HPI 39T spur gear will boost the car above 70mph!!!
FEAR TRAXXAS!!!
       Post #: 10
RE: Physics and equations of top speed+torque!!! - 4/14/2008 8:33:44 PM
dsales
Status: offline
...Or a could just save time and buy a schumacher fusion and completely destroy you
       Post #: 11
RE: Physics and equations of top speed+torque!!! - 4/14/2008 8:41:00 PM
GYNAIKAS
Status: offline
Till the first corner ...then the fusion yould be somewhere out of the track...and the RS4 still running. And if the fusion managed to corner the RS4 corners 3 times faster!!!
       Post #: 12
RE: Physics and equations of top speed+torque!!! - 4/14/2008 8:53:08 PM
Danker16
Status: offline
yo thanks man i have been looking for something similar to get a top speed of my OS 18TM, it looks pretty simple actually.!
Revo 2.5/18TM, Tekno casing, 645GM single steering,Wing mount, Wabash 23mm rims, aluminum pushrods and turnies.
       Post #: 13
RE: Physics and equations of top speed+torque!!! - 4/14/2008 9:35:00 PM
GYNAIKAS
Status: offline
No problem! I like physics...brain training...
(in reply to Danker16)
       Post #: 14
RE: Physics and equations of top speed+torque!!! - 4/14/2008 11:20:05 PM
ferrarimk13
Status: offline
man, is this what ill have to look forward to in AP physics? thanks for making it though, ill re read it and try to understand.
press Alt+F4 for a good time.
       Post #: 15
RE: Physics and equations of top speed+torque!!! - 4/15/2008 12:13:45 AM
GYNAIKAS
Status: offline
Physics is easy once you open your mind and realise that you can do magic things with it! It''s really several times easier than it looks!
(in reply to ferrarimk13)
