HELP PLEASE!!!! ANYONE! need a balancer.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> HELP PLEASE!!!! ANYONE! need a balancer.
Page: [1]
Login
HELP PLEASE!!!! ANYONE! need a balancer. - 4/14/2008 3:45:49 PM
javiwood
Status: offline
Hello all! im in need of some assistance. I have recently up my losi 8T with a losi 2000 lipo pack. I then also purchased a new lipo charger, i went with the Triton 2 charger. But what i didnt realize when i purchased it is that it doesn''t balance lipos. So i was looking to buy a balancer to use with my charger. Well now my LHS told me that i wouldnt be able to find a balancer that will balance my losi lipo pack and the only one that would work is the LOSI CHARGER wich means i would have to buy a new charger. is this true or can anyone tell me what balacer is compatable with a LOSI LIPO with out having to buy all new again!! or does anybody else make a lipo that will fit my 8T, ive been told that losi lipos are the only ones that work, is this true? all input is appreciated.
Thanks again!!
Stumped & Frustrated!
       Post #: 1
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/14/2008 4:11:57 PM
BigTb17
Status: offline
I''m sure there are many LiPo batteries that would work for your application. You don''t have to use the Losi battery.
However, since you have it you might as well use it. I don''t see why a Astro Blinky balancer wouldn''t work. You may also be able to get an adapter to make your Losi balance connector plug into an Equinox balancer (or similar) if you prefer that route. If you can''t buy the exact adapter, you can just buy a connector with leads and splice it to your battery''s balance lead.
(in reply to javiwood)
       Post #: 2
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/14/2008 4:16:13 PM
richrd
Status: offline
I agree if the balance plug on Lossi is gnd,3.7, 7.4 in other adds from ground then the Blinkly is the best low cost their is IMHO.
Link the battery so we may be of more techy help.
Rich
(in reply to BigTb17)
       Post #: 3
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/14/2008 6:02:36 PM
SavageX78
Status: offline
Well this must be the 1 he has its the only 2000Mah lipo that losi makes. Or at least the only 1 i could find on there site.
Losi lipo
Edit Hers the balancer that goes with the triton 2 Equinox
But im sure you could use any balancer that is compatible.
< Message edited by MF2MM5700 -- 4/14/2008 6:12:20 PM >
_____________________________
RCs : XXX-T MF2 ~ Xray M18 ~ Micro-T~ E-maxx 3905 ~ Mardave Cobra ~ Old Lunchbox (needs Restoration)
(in reply to richrd)
       Post #: 4
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/14/2008 7:10:26 PM
javiwood
Status: offline
thats the the one i have! the losi 2000. how do i know if the balancer lead will match up with the balancer. thats where ive been told it wont work. they ( LHS ) also said that they didnt recomend cutting the lead for the possibility of damaging the lipo.
(in reply to SavageX78)
       Post #: 5
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/14/2008 7:34:47 PM
SavageX78
Status: offline
I dont know much about lipo but if your connector is the same as the 1 on this pack. It should work. take a close look. As far as I know all balancers serve the same purpose so as long as the plug will fit there should be no reason it wont work.
My local hobby shop has led me in the wrong direction so many times I stoped asking them questions.
Im sure some1 with more experience with the losi lipo packs will chime in to help.
I did some googleing and I did find a post were somebody was useing a Venom balancer with there losi lipos. So there is hope. lol
       Post #: 6
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/15/2008 12:43:42 AM
BigTb17
Status: offline
quote:
ORIGINAL: MF2MM5700
It the Losi works with the Venom balancer you can use the Equinox balancer with your Triton 2 to balance your battery. Venom batteries have the same balance plug as the Great Planes batteries/balancers.
If your Losi battery has the same connector simply get the Equinox balancer and your good to go.
       Post #: 7
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/15/2008 12:16:45 PM
BobMaine
Status: offline
Check to see if the Blinky balancer you are considering has REVERSE POLARITY protection. Some don''t and if you plug it in backwards you will FRY your Blinky. I learned this the hard way...
I crewed on USAF cargo planes so long ago we worried about bird strikes from the rear...
       Post #: 8
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/15/2008 5:45:43 PM
richrd
Status: offline
Well the real guestion comes in with the overcharge protect wording if that was your pack. This has been causing some real greef with some chargers and balancers. But as i said if you have the ablity to read a meter just checking the balance plug will tell you alot. The OV is a trail an error thing untell someone that has this pack cimes in here.
Rich
(in reply to BobMaine)
       Post #: 9
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/26/2008 3:56:27 AM
RevoDave
Status: offline
Just got the losi lipo for my 8 today and already have the triton charger. The balance plug does not plug into the Equinox balancer. Will have to splice in or find adapter.
       Post #: 10
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/28/2008 6:47:26 PM
buglite62
Status: offline
quote:
ORIGINAL: RevoDave
Did you find any solution, I've had no luck so far. Where can you buy a pigtail to splice onto the pack at? This is my first lipo so I don't have any to rob from. Thanks
scott
(in reply to RevoDave)
       Post #: 11
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/28/2008 7:42:11 PM
SavageX78
Status: offline
I sent losi a email when this thread started and they just got back to me they state:
"thank you for your recent e-mail. I am not familiar with the Eqinox charger. The Losi plugs are the same as the Thunder Power balance plugs. If the charger is compatible with Thunder Power then it will work with the Losi battery"
So I guess anything that will balance TP batts will do the losi lipos too.
(in reply to buglite62)
       Post #: 12
RE: HELP PLEASE!!!! ANYONE! need a balancer. - 4/28/2008 8:12:04 PM
BigTb17
Status: offline
quote:
ORIGINAL: MF2MM5700
In that case you can get a Thunder Power balance adapter for the Equinox balancer at Common Sense RC's website for like $3-$4.
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
